Login Error: Avaya one-X Communicator is unable to connect to the server.
Make sure that you have entered the correct IP address or domain name information.
Try to login again. If you are still unable to login, there is a problem with your network
(for example, the network is "down", or your LAN cable is disconnected or defective).
Contact your system administrator.
Avaya Onex Communicator Is Unable To Connect To The Server
Avaya Onex Communicator Is Unable To Connect To The Server (31.41 KiB) Viewed 5882 times
