You must remove text message two-factor authentication (Twitter)
Only Twitter Blue subscribers can use the text message two-factor authentication method. It'll just take a few minutes to remove it. You can still use the authentication app and security key methods. To avoid losing access to Twitter, remove text message two-factor authentication by Mar 19, 2023.
You Must Remove Text Message Two Factor Authentication Twitter
You Must Remove Text Message Two Factor Authentication Twitter (106.51 KiB) Viewed 7073 times
