Google Analytics 4 is replacing Universal Analytics
Google Analytics 4 is our next-generation measurement solution, and is replacing Universal Analytics. On July 1, 2023, Universal Analytics properties will stop processing new hits. If you still rely on Universal Analytics, we recommend that you complete your move to Google Analytics 4.
MANAGE YOUR GOOGLE ANALYTICS 4 SETUP
You've already created a Google Analytics 4 property. Now's the time to ensure that your setup is complete. If you haven't started collecting data in your Google Analytics 4 property, you should do so now. This will allow you to gather the historical insights you need to measure your results over time when Universal Analytics stops processing hits. If you are already collecting the data you need in Google Analytics 4, you should ensure your remaining setup is complete.
You can continue to use and collect new data in your Universal Analytics properties until July 1, 2023. After that, you will be able to access your previously processed data in Universal Analytics for a period of at least six months. We know your data is important to you and we strongly encourage you to export your historical reports during this time.
In the coming months, we will provide a future date for when we will fully sunset Universal Analytics. On this sunset date, you will no longer be able to see your Universal Analytics reports in the Analytics interface or access your Universal Analytics data via the API.
If you have questions on successfully making the switch to Google Analytics 4, check out our Help Center resources.
See you online,
The Google Analytics Team
We will begin to sunset Universal Analytics in 2023
