[frame=0x10bcca100, main=1] FrameLoader::load (DocumentLoader): frame load started
0x10bc93000 - PerformanceMonitor::measureCPUUsageInActivityState: Process is using 0.9% CPU in state: NonVisible
0x10bc93000 - PerformanceMonitor::measureCPUUsageInActivityState: Process is using 9.7% CPU in state: NonVisible
0x10bc93000 - PerformanceMonitor::measurePostLoadCPUUsage: Process was using 0.0% CPU after the page load.
0x10bc93000 - PerformanceMonitor::measurePostLoadMemoryUsage: Process was using 117334016 bytes of memory after the page load.
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::checkLoadCompleteForThisFrame: Finished frame load
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::continueLoadAfterNavigationPolicy: Setting provisional document loader (m_provisionalDocumentLoader=0x1190f7800)
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::load (DocumentLoader): frame load started
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::load (FrameLoadRequest): frame load started
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::loadWithDocumentLoader: frame load started
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::loadWithDocumentLoader: main frame load started
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::prepareForLoadStart: Starting frame load
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::setProvisionalDocumentLoader: Setting provisional document loader (m_provisionalDocumentLoader=0x0)
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::setProvisionalDocumentLoader: Setting provisional document loader (m_provisionalDocumentLoader=0x1190f7800)
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::setState: main frame load completed
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::stopAllLoaders: Clearing provisional document loader (m_provisionalDocumentLoader=0x0)
0x10bca7000 - [frame=0x10bcca100, main=1] FrameLoader::transitionToCommitted: Clearing provisional document loader (m_provisionalDocumentLoader=0x1190f7800)
0x10bcfdab0 - ProgressTracker::finalProgressComplete: value 0.100000, tracked frames 0, originating frame 0x10bcca100, isMainLoad 1, isMainLoadProgressing 1
0x10bcfdab0 - ProgressTracker::progressCompleted: frame 0x10bcca100, value 0.100000, tracked frames 1, originating frame 0x10bcca100, isMainLoad 1
0x10bcfdab0 - ProgressTracker::progressStarted: frame 0x10bcca100, value 0.100000, tracked frames 1, originating frame 0x10bcca100, isMainLoad 1
0x111993000 - PerformanceMonitor::measureCPUUsageInActivityState: Process is using 81.6% CPU in state: VisibleNonActive
0x1119a7000 - [frame=0x1119ca100, main=1] FrameLoader::setProvisionalDocumentLoader: Setting provisional document loader (m_provisionalDocumentLoader=0x0)
0x1119a7000 - [frame=0x1119ca100, main=1] FrameLoader::setProvisionalDocumentLoader: Setting provisional document loader (m_provisionalDocumentLoader=0x114df6000)
0x1119a7000 - [frame=0x1119ca100, main=1] FrameLoader::setState: main frame load completed
0x1119a7000 - [frame=0x1119ca100, main=1] FrameLoader::transitionToCommitted: Clearing provisional document loader (m_provisionalDocumentLoader=0x114df6000)
0x114df6000 - DocumentLoader::startLoadingMainResource: Returning empty document (frame = 0x1119ca100, main = 1)
0x1190f7800 - DocumentLoader::startLoadingMainResource callback: Load canceled because of substitute data (frame = 0x10bcca100, main = 1)
0x1190f7800 - DocumentLoader::startLoadingMainResource: Returning substitute data (frame = 0x10bcca100, main = 1)
0x1190f7800 - DocumentLoader::startLoadingMainResource: Starting load (frame = 0x10bcca100, main = 1)
0x1193eed80 - SubresourceLoader::willCancel: (frame = 0x10bcca100, frameLoader = 0x10bca7000, resourceID = 32, type = 3, code = -999)
0x11c38a480 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::validateCommand'
0x11c38a480 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::validateCommand'
0x11c3ecd00 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ecd00 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ecd40 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ecd40 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ecd70 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ecd70 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ece40 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ece40 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ece70 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ece70 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3eceb0 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3eceb0 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ecee0 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ecee0 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'WebPageProxy::runJavaScriptInMainFrameScriptWorld'
0x11c3ff000 - CachedResource::load: Unable to create SubresourceLoader (frame = 0x10bcca100)
0x11c86a2f0 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'RemoteObjectRegistry invocation'
0x11c86a2f0 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'RemoteObjectRegistry invocation'
0x11c86a330 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'RemoteObjectRegistry invocation'
0x11c86a330 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'RemoteObjectRegistry invocation'
0x11c86a500 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'RemoteObjectRegistry invocation'
0x11c86a500 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'RemoteObjectRegistry invocation'
0x11c86a530 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::Activity: Starting background activity / 'RemoteObjectRegistry invocation'
0x11c86a530 - [PID=0, throttler=0x10bca4498] ProcessThrottler::Activity::invalidate: Ending background activity / 'RemoteObjectRegistry invocation'
0x409c82090 - ProgressTracker::finalProgressComplete: value 0.234609, tracked frames 0, originating frame 0x409cd7300, isMainLoad 1, isMainLoadProgressing 1
0x409c82090 - ProgressTracker::progressCompleted: frame 0x409cd7300, value 0.234609, tracked frames 1, originating frame 0x409cd7300, isMainLoad 1
0x409c82090 - ProgressTracker::progressStarted: frame 0x409cd7300, value 0.100000, tracked frames 1, originating frame 0x409cd7300, isMainLoad 1
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::checkLoadCompleteForThisFrame: Finished frame load
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::continueLoadAfterNavigationPolicy: Setting provisional document loader (m_provisionalDocumentLoader=0x409ee1c00)
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::load (DocumentLoader): frame load started
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::load (FrameLoadRequest): frame load started
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::loadWithDocumentLoader: frame load started
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::loadWithDocumentLoader: main frame load started
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::prepareForLoadStart: Starting frame load
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::setProvisionalDocumentLoader: Setting provisional document loader (m_provisionalDocumentLoader=0x0)
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::setProvisionalDocumentLoader: Setting provisional document loader (m_provisionalDocumentLoader=0x409ee1c00)
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::setState: main frame load completed
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::stopAllLoaders: Clearing provisional document loader (m_provisionalDocumentLoader=0x0)
0x409cd6300 - [frame=0x409cd7300, main=1] FrameLoader::transitionToCommitted: Clearing provisional document loader (m_provisionalDocumentLoader=0x409ee1c00)
0x409ced320 - PerformanceMonitor::measureCPUUsageInActivityState: Process is using 0.0% CPU in state: NonVisible
0x409ced320 - PerformanceMonitor::measureCPUUsageInActivityState: Process is using 0.6% CPU in state: NonVisible
0x409ced320 - PerformanceMonitor::measureCPUUsageInActivityState: Process is using 3.1% CPU in state: VisibleAndActive
0x409ced320 - PerformanceMonitor::measurePostBackgroundingCPUUsage: Process was using 0.0% CPU after becoming non visible.
0x409ced320 - PerformanceMonitor::measurePostBackgroundingMemoryUsage: Process was using 32522240 bytes of memory after becoming non visible.
0x409ced320 - PerformanceMonitor::measurePostLoadCPUUsage: Process was using 0.1% CPU after the page load.
0x409ced320 - PerformanceMonitor::measurePostLoadMemoryUsage: Process was using 32919552 bytes of memory after the page load.
0x409cf4690 - [webFrame=0x7fec8f525038, webFrameID=3, webPage=0x7fec8800aa08, webPageID=12] WebFrameLoaderClient::dispatchDidReachLayoutMilestone: dispatching DidFirstLayoutForFrame
0x409cf4690 - [webFrame=0x7fec8f525038, webFrameID=3, webPage=0x7fec8800aa08, webPageID=12] WebFrameLoaderClient::dispatchDidReachLayoutMilestone: dispatching DidFirstVisuallyNonEmptyLayoutForFrame
0x409cf4690 - [webFrame=0x7fec8f525038, webFrameID=3, webPage=0x7fec8800aa08, webPageID=12] WebFrameLoaderClient::dispatchDidReachLayoutMilestone: dispatching DidReachLayoutMilestone (milestones=DidFirstLayout, DidFirstVisuallyNonEmptyLayout)
0x409cf4690 - [webFrame=0x7fec8f525038, webFrameID=3, webPage=0x7fec8800aa08, webPageID=12] WebFrameLoaderClient::dispatchDidReachLayoutMilestone: dispatching DidReachLayoutMilestone (milestones=DidFirstLayoutAfterSuppressedIncrementalRendering)
0x409cf4690 - [webFrame=0x7fec8f525038, webFrameID=3, webPage=0x7fec8800aa08, webPageID=12] WebFrameLoaderClient::dispatchDidReachLayoutMilestone: dispatching DidReachLayoutMilestone (milestones=DidFirstPaintAfterSuppressedIncrementalRendering)
0x409cf5000 - [resourceLoader=0x409dc7200, frameLoader=0x409cd6300, frame=0x409cd7300, webPageID=12, frameID=3, resourceID=56] WebLoaderStrategy::scheduleLoad: Resource is being scheduled with the NetworkProcess (priority=3)
0x409cf5000 - [resourceLoader=0x409dc7200, frameLoader=0x409cd6300, frame=0x409cd7300, webPageID=12, frameID=3, resourceID=56] WebLoaderStrategy::scheduleLoad: URL will be scheduled with the NetworkProcess
0x409cf5000 - [resourceLoader=0x409dc7b00, frameLoader=0x409cd6300, frame=0x409cd7300, webPageID=12, frameID=3, resourceID=57] WebLoaderStrategy::scheduleLoad: Resource is being scheduled with the NetworkProcess (priority=1)
0x409cf5000 - [resourceLoader=0x409dc7b00, frameLoader=0x409cd6300, frame=0x409cd7300, webPageID=12, frameID=3, resourceID=57] WebLoaderStrategy::scheduleLoad: URL will be scheduled with the NetworkProcess
0x409cf7000 - [sessionID=1] WebProcess::destroyRenderingResources: took 3.89ms
0x409dc7200 - SubresourceLoader::didFinishLoading: (frame = 0x409cd7300, frameLoader = 0x409cd6300, resourceID = 56)
0x409dc7b00 - SubresourceLoader::didFinishLoading: (frame = 0x409cd7300, frameLoader = 0x409cd6300, resourceID = 57)
0x409ee1c00 - DocumentLoader::startLoadingMainResource callback: Load canceled because of substitute data (frame = 0x409cd7300, main = 1)
0x409ee1c00 - DocumentLoader::startLoadingMainResource: Returning substitute data (frame = 0x409cd7300, main = 1)
0x409ee1c00 - DocumentLoader::startLoadingMainResource: Starting load (frame = 0x409cd7300, main = 1)
0x40ae70010 - [frame=0x409cd7300, main=1] FrameView::fireLayoutRelatedMilestonesIfNeeded: Firing first visually non-empty layout milestone on the main frame
0x40b3934c8 - [webPageID=12, frameID=3, resourceID=56] WebResourceLoader::didFinishResourceLoad: (length=16749)
0x40b3934c8 - [webPageID=12, frameID=3, resourceID=56] WebResourceLoader::didReceiveData: Started receiving data
0x40b3934c8 - [webPageID=12, frameID=3, resourceID=56] WebResourceLoader::didReceiveResponse: (httpStatusCode=200)
0x40b393ab0 - [webPageID=12, frameID=3, resourceID=57] WebResourceLoader::didFinishResourceLoad: (length=37)
0x40b393ab0 - [webPageID=12, frameID=3, resourceID=57] WebResourceLoader::didReceiveData: Started receiving data
0x40b393ab0 - [webPageID=12, frameID=3, resourceID=57] WebResourceLoader::didReceiveResponse: (httpStatusCode=200)
0x7fb70c6147f0: Posting CNCDContactStoreDidChangeNotification because accounts changed
0x7fcd84e12120(0x7fcd84e0d410) is unlocked; decoding for makeUnlocked()
0x7fcd8682f920(0x7fcd84e0d410) is unlocked; decoding for makeUnlocked()
0x7fcd8690d4e0(0x7fcd84e0d410) is unlocked; decoding for makeUnlocked()
0x7fcd86a197d0(0x7fcd84e0d410) is unlocked; decoding for makeUnlocked()
0x7fcd86d172d0(0x7fcd84e0d410) is unlocked; decoding for makeUnlocked()
0x7fcd8790c2a0(0x7fcd84e0d410) is unlocked; decoding for makeUnlocked()
