The password you use to unlock this Mac will also used to access saved passwords and other sensitive data you store in..
The Password You Use To Unlock This Mac Will Also Be Used To Access Saved Passwords
The Password You Use To Unlock This Mac Will Also Be Used To Access Saved Passwords (30.93 KiB) Viewed 1039 times
Enter your Mac password
The password you use to unlock this Mac will also used to access saved passwords and other sensitive data you store in iCloud.
