My Folder 1 - eBay (WON'T DELETE!!)
Ebay My Folder 1
Ebay My Folder 1 (68.89 KiB) Viewed 3740 times
Re: My Folder 1 - eBay (WON'T DELETE!!)
Post by Guest »
Click to rename the folder name and enter this: "⠀"
But you have to remove the quotes. It is the empty unicode space.
It won't "fix" it, but it will remove the annoying "My folder 1" name.
Good luck!
