The remote computer that you are trying to connect to requires Network Level Authentication (NLA)
Remote Desktop Connection
The remote computer that you are trying to connect to requires Network Level Authentication (NLA), but Windows domain controller cannot be contacted to perform NLA. If you are an administrator on the remote computer, you can disable NLA by using the options on the Remote tab of the System Properties dialog box.
Remote Desktop Connection The Remote Computer That You Are Trying
Remote Desktop Connection The Remote Computer That You Are Trying (115.2 KiB) Viewed 4472 times
