The item is either locked or damages, or in a folder you don't have permission to modify (error code -5000)
You can't change the item "" to always open in the selected application.
You Cant Change The Item To Always Open In The Selected Application
You Cant Change The Item To Always Open In The Selected Application (29.66 KiB) Viewed 3822 times
