Reported failure reason: socket error (Soulseek Mac)
If you are getting this error in macOS, go to your network settings -> network connection -> proxies -> and check to see if SOCKS proxy is enabled. Sometimes this is enabled by unknown applications. Disable it.
Socket Error Soulseek Mac
Socket Error Soulseek Mac (157.82 KiB) Viewed 3108 times
Login failed. Reported failure reason: socket error. Please change your login setting in the Options tab and try reconnecting.
