If you are associating to another active AdSense account, the association process usually takes a couple minutes.
Youtube Associate Another Adsense Account
Youtube Associate Another Adsense Account (50.05 KiB) Viewed 715 times
You will be redirected to AdSense to complete this step
If you are associating to another active AdSense account, the association process usually takes a couple minutes. If you are creating a new AdSense account, the approval and association process can take up to several days. Monetization will commence when the association is completed.
To avoid interrupting your monetization, check if you can make changes to your existing AdSense account instead.
Learn more
