Your document will be upgraded to the newest file format.
Microsoft Word
While you'll get to use all the new features in Word, some minor layout changes are possible. If you prefer not to upgrade, press cancel and check the maintain compatibility checkbox.
Word Document Will Be Upgraded To The Newest File Format
Word Document Will Be Upgraded To The Newest File Format (18.68 KiB) Viewed 3946 times
