Your graphics card cannot successfully connect to your HMD display. (436)
Your Graphics Card Cannot Successfully Connect To Your HMD Display 436
Your Graphics Card Cannot Successfully Connect To Your HMD Display 436 (159.2 KiB) Viewed 775 times
Display Connection Trouble
Your graphics card cannot successfully connect to your HMD display. try removing any cable adapters or extenders you're using. Try another port on your GPU if one is available. Use the reset link below to reset the HMD so the GPU will try again.
