Your internet connection is not fast enough (Netflix) (13015)
Your Internet Connection Is Not Fast Enough Netflix
Your Internet Connection Is Not Fast Enough Netflix (53.25 KiB) Viewed 4015 times
Your internet connection is not fast enough. Please connect using Wi-FI or at least 3G (13015)
Re: Your internet connection is not fast enough (Netflix) (13015)
Post by Guest »
its happen to me when i open netflix using data sellular. it said that your connection is not fast enough, please connect using Wifi or at least 3G (even my connection is in 4G+ mode
JonSnow
Post by JonSnow »
I had the same problem in my phone. I just turned on Airplane mode and turned it off and the problem is solved.
