You shut down your computer because of a problem.
If you want to open the applications that were open when you shut down, click Open.
If you do nothing, the computer will continue the login in "" seconds.
Your Computer Shut Down Because Of A Problem
Your Computer Shut Down Because Of A Problem (88.32 KiB) Viewed 2875 times
