- Your Phone Number Is Incorrect Or Unsupported Clubhouse (34.06 KiB) Viewed 1146137 times
Your phone number is incorrect or unsupported (Clubhouse)
Re: Your phone number is incorrect or unsupported (Clubhouse)
Maybe u can use this, first u must login use your another phone number, after that u back again to login page and use your first phone number.
Claire from PH
Is it possible that it's not available in my country? I'm from the Philippines.
Maha Abulhasan
I got message from club house that my number incorrect 69086800
Himynameisjeff
I deactivated the app and after that i could not log in anymore and the error started showing up at the home page. I get the code send to my number but ehen i use the code it gives an error
pooja_bh
Iam unable to login to my account. Even though I enter the correct number it’s showing like your number is incorrect or unsupported. And Iam unable to receive verification code
Nashina Nishad
I'm using clubhouse app over two months. Few hours before, I deactivate my account and now I login , I cannot get any otp. So I restart my phone and then I enter my number , they shows " your phone number is incorrect or unsupported". Please find the solution as soon as possible
Thank you
Thank you
I can't log in because I have been told that my number is not correct and that my number is correct
rebinahmed
Jv_7703 wrote:
> Yeah mine too
> Yeah mine too
rebinahmed
Jv_7703 wrote:
> Yeah mine too
Yes
> Yeah mine too
Yes
rebinahmed
rebinahmed
rebinahmed
Why my phone number is unsupported in Clubhouse?
alishbakamran
My number is supported and working , it’s connected to the app and yet not logging in
Sankar
our systems have detected high usage of this feature
iamrachele1
I need this error to be fix on my account +18776661628
I can’t receive login code because it says incorrect number or unsupported number please I need you guys to fix this errors on my account
Edwaish
It's been almost 48 hours now and I can't login with my number, I have sent the tech support and have done everything recommended in their automated email of solutions and yet nothing worked, I can login using any other account but mine!
