May 17 15:25:29 Installer Progress[104]: Showing Progress UI
May 17 15:25:29 Installer Progress[104]: HotKeys disabled
May 17 15:25:29 Installer Progress[104]: Progress app set to foreground app
May 17 15:25:29 Installer Progress[104]: _LSSetMetaApplicationInformationItem add to frontmost list success
May 17 15:25:29 Installer Progress[104]: Showing the windows
May 17 15:25:29 Installer Progress[104]: There are 0 window(s) and 1 display(s), 1 window(s) will be added
May 17 15:25:29 Installer Progress[104]: Created a window at {{0, 0}, {960, 540}}
May 17 15:25:29 Installer Progress[104]: Adding Apple Logo
May 17 15:25:29 Installer Progress[104]: Apple logo view created
May 17 15:25:29 Installer Progress[104]: Status is ""
May 17 15:25:29 Installer Progress[104]: Alternate status is ""
May 17 15:25:29 Installer Progress[104]: no background for progress added because:
May 17 15:25:29 Installer Progress[104]: no boot window list
May 17 15:25:29 Installer Progress[104]: IASPIsUsingFileVault NO
May 17 15:25:29 Installer Progress[104]: IASPGetBootMode Standard
May 17 15:25:29 Installer Progress[104]: and / or NOT booting from EFI loginwindow
May 17 15:25:29 Installer Progress[104]: _ShowUnmanagedSpace: 80103: Showing Unmanaged Space 2
May 17 15:25:29 Installer Progress[104]: Setting window alpha values to 1.0
May 17 15:25:29 Installer Progress[104]: Ordering windows front
May 17 15:25:29 Installer Progress[104]: Created CG Shield Window
May 17 15:25:29 Installer Progress[104]: Enable the display of progress windows
May 17 15:25:29 Installer Progress[104]: Using AppKit display change notification
May 17 15:25:29 Installer Progress[104]: Done with phase = "IOKit Boot"
May 17 15:25:29 Installer Progress[104]: Progress Updated: currentPhase = "IOKit Boot", phase progress = 100.000, total progress = 23.535
May 17 15:25:29 Installer Progress[104]: IASSetCurrentInstallPhase: Current phase name set to "loginwindow Boot"
May 17 15:25:29 Installer Progress[104]: Saving completion handler for phase IOKit Boot
May 17 15:25:29 Installer Progress[104]: Connected processes {
"1185B14B-3817-4BCA-A7DD-308D48FCAE60" = {
CompletionHandlerKey = "<__NSMallocBlock__: 0x600002f94910>";
"Phase Name" = "IOKit Boot";
"Process ID" = 144;
UUID = "1185B14B-3817-4BCA-A7DD-308D48FCAE60";
"E2AB3BA4-5ABF-478B-83D1-28764BE0F330" = {
CompletionHandlerKey = "<__NSMallocBlock__: 0x600002fb1180>";
"Phase Name" = "loginwindow Boot";
"Process ID" = 144;
UUID = "E2AB3BA4-5ABF-478B-83D1-28764BE0F330";
May 17 15:25:29 Installer Progress[104]: Unregister process 144, phaseName IOKit Boot, uuid 1185B14B-3817-4BCA-A7DD-308D48FCAE60
"Process ID" = 144;
May 17 15:25:29 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 10.000, total progress = 31.182
May 17 15:25:29 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 30.000, total progress = 46.475
May 17 15:25:29 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 55.000, total progress = 65.591
May 17 15:25:29 loginwindow[144]: USER_PROCESS: 144 console
May 17 15:25:30 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 80.000, total progress = 84.707
May 17 15:25:30 Installer Progress[104]: Moving window from {{0, 0}, {960, 540}} to {{0, 0}, {1920, 1080}}
May 17 15:25:30 Installer Progress[104]: Setting window alpha values to 1.0
May 17 15:25:30 --- last message repeated 1 time ---
May 17 15:25:30 loginwindow[144]: client 0x600001666c40: phaseName = "loginwindow Boot" is done
May 17 15:25:30 loginwindow[144]: ISAP: Done with Phase "loginwindow Boot"
May 17 15:25:30 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 100.000, total progress = 100.000
May 17 15:25:30 Installer Progress[104]: Done with phase = "loginwindow Boot"
May 17 15:25:30 Installer Progress[104]: IASClearInstallProgress: Clearing Registry
May 17 15:25:31 Installer Progress[104]: Ignoring the progress update because "loginwindow Boot" isn't one of the phases (null)
May 17 15:25:31 Installer Progress[104]: Calling animation completion handler
May 17 15:25:31 Installer Progress[104]: Progress complete, notifying registered clients
May 17 15:25:31 Installer Progress[104]: Calling completion handler for phase "loginwindow Boot"
May 17 15:25:31 loginwindow[144]: Calling completion handler for 0x600001666c40
May 17 15:25:31 loginwindow[144]: client 0x600001666c40: phaseName = "loginwindow Boot", hide progress UI called
May 17 15:25:31 loginwindow[144]: ISAP: hide progress UI called
May 17 15:25:31 loginwindow[144]: client 0x600001666c40: phaseName = "loginwindow Boot" is being released
May 17 15:25:31 loginwindow[144]: Releasing Connection
May 17 15:25:31 Installer Progress[104]: Hiding Progress UI
May 17 15:25:31 Installer Progress[104]: Showing the cursor in Progress UI
May 17 15:25:31 Installer Progress[104]: GUI session is logged in
May 17 15:25:31 Installer Progress[104]: Order Out CG Shield Window
May 17 15:25:31 Installer Progress[104]: Setting window alpha values to 0.0
May 17 15:25:31 Installer Progress[104]: Progress app removed from the frontmost only list
May 17 15:25:31 Installer Progress[104]: Progress app set to Background only app
May 17 15:25:31 Installer Progress[104]: HotKeys enabled
May 17 15:25:31 Installer Progress[104]: Start quit timer, will attempt to quit in 5 second(s) at 3:25:36 PM
May 17 15:25:31 Installer Progress[104]: Saving completion handler for phase loginwindow Boot
May 17 15:25:31 Installer Progress[104]: Connected processes {
CompletionHandlerKey = "<__NSMallocBlock__: 0x600002f80a00>";
"Process ID" = 144;
May 17 15:25:31 Installer Progress[104]: Unregister process 144, phaseName loginwindow Boot, uuid E2AB3BA4-5ABF-478B-83D1-28764BE0F330
May 17 15:25:31 Installer Progress[104]: Activated application <NSRunningApplication: 0x600002282480 (com.apple.finder - 359) LSASN:{hi=0x0;lo=0x12012}>
May 17 15:25:31 Installer Progress[104]: Ordering windows out
May 17 15:25:36 Installer Progress[104]: Quitting because there are no phases. There are no connected processes. The UI is not showing.
May 17 15:25:36 Installer Progress[104]: Quitting Progress App
May 17 15:25:36 Installer Progress[104]: Showing the cursor in Progress UI
May 17 15:25:36 Installer Progress[104]: GUI session is logged in
May 17 15:25:36 Installer Progress[104]: Order Out CG Shield Window
May 17 15:25:36 Installer Progress[104]: Setting window alpha values to 0.0
May 17 15:25:36 loginwindow[144]: The connection was interrupted, calling interruption handlers
May 17 15:26:28 loginwindow[144]: There is still an active connection
May 17 15:27:01 --- last message repeated 1 time ---
May 17 15:30:01 syslogd[107]: Configuration Notice:
ASL Module "com.apple.cdscheduler" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
ASL Module "com.apple.authd" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.contacts.ContactsAutocomplete" claims selected messages.
ASL Module "com.apple.mkb" sharing output destination "/private/var/log/keybagd.log" with ASL Module "com.apple.mkb.internal".
Output parameters from ASL Module "com.apple.mkb.internal" override any specified in ASL Module "com.apple.mkb".
ASL Module "com.apple.mkb" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
May 17 15:35:52 syslogd[107]: ASL Sender Statistics
May 17 15:54:39 syslogd[107]: ASL Sender Statistics
May 17 16:03:16 sessionlogoutd[2230]: DEAD_PROCESS: 144 console
May 17 16:03:16 shutdown[2232]: SHUTDOWN_TIME: 1652821396 565903
May 17 16:03:26 localhost bootlog[0]: BOOT_TIME 1652821406 802368
May 17 16:03:30 localhost syslogd[107]: Configuration Notice:
May 17 16:03:30 localhost Installer Progress[104]: Progress UI App Starting
May 17 16:03:30 localhost syslogd[107]: ASL Sender Statistics
May 17 16:03:32 Installer Progress[104]: No boot windows available
May 17 16:03:32 Installer Progress[104]: Hiding the cursor in Progress UI
May 17 16:03:32 Installer Progress[104]: Configuration is deferred 1
May 17 16:03:32 loginwindow[146]: Clearing phase info
May 17 16:03:32 loginwindow[146]: calling progress app remoteObjectProxy
May 17 16:03:32 loginwindow[146]: Creating connection
May 17 16:03:32 loginwindow[146]: Connection = 0x600000a78500, callers = (
"<IASUPCaller: 0x60000397ced0>"
May 17 16:03:32 Installer Progress[104]: caller = /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
May 17 16:03:32 Installer Progress[104]: Version 2
May 17 16:03:32 loginwindow[146]: version = 2
May 17 16:03:32 loginwindow[146]: isModernOS = 1
May 17 16:03:32 loginwindow[146]: Add phase named "IOKit Boot", progress 23.144531, delayInSeconds 0
May 17 16:03:32 Installer Progress[104]: Clearing phase info
May 17 16:03:32 loginwindow[146]: Add phase named "loginwindow Boot", progress 76.855469, delayInSeconds -1
May 17 16:03:32 Installer Progress[104]: IASGetCurrentInstallPhaseList: Unable to get phases
"<IASUPCaller: 0x60000397ced0>",
"<IASUPCaller: 0x600003974410>"
May 17 16:03:32 loginwindow[146]: client 0x600002e39200: phaseName = "loginwindow Boot", registering connection
May 17 16:03:32 Installer Progress[104]: IASGetCurrentInstallPhase: Unable to get the current phase name
May 17 16:03:32 Installer Progress[104]: Current phase name wasn't saved, using the first phase in the list, current phase = "(null)"
May 17 16:03:32 loginwindow[146]: client 0x600002e39200: phaseName = "loginwindow Boot" was created
May 17 16:03:32 Installer Progress[104]: currentPhase = "(null)", phases = (null)
"<IASUPCaller: 0x600003974410>",
"<IASUPCaller: 0x600003960820>"
May 17 16:03:32 loginwindow[146]: client 0x600002e4e100: phaseName = "IOKit Boot", registering connection
May 17 16:03:32 Installer Progress[104]: IASClearInstallProgress: Clearing Registry
May 17 16:03:32 loginwindow[146]: client 0x600002e4e100: phaseName = "IOKit Boot" was created
May 17 16:03:32 loginwindow[146]: client 0x600002e4e100: phaseName = "IOKit Boot", show progress UI called
May 17 16:03:32 loginwindow[146]: ISAP: Show progress UI called
May 17 16:03:32 loginwindow[146]: client 0x600002e4e100: phaseName = "IOKit Boot" is done
May 17 16:03:32 loginwindow[146]: ISAP: Done with Phase "IOKit Boot"
May 17 16:03:32 loginwindow[146]: client 0x600002e4e100: phaseName = "IOKit Boot" is being released
May 17 16:03:32 loginwindow[146]: Releasing Connection
May 17 16:03:32 loginwindow[146]: client 0x600002e39200: handler = 0x16f542008
May 17 16:03:32 Installer Progress[104]: Progress app is loading…
May 17 16:03:32 Installer Progress[104]: Progress app is running with no progress set
May 17 16:03:32 Installer Progress[104]: Progress app is running…
May 17 16:03:32 Installer Progress[104]: totalPercentage = 0.000000
"<IASPPhase: 0x6000032dfa00: 'IOKit Boot', percentage 23.1, delay 0>"
May 17 16:03:32 Installer Progress[104]: IASSetCurrentInstallPhaseList: phases set to (
ConclusionDelay = 0;
InstallPhase = "IOKit Boot";
InstallPhaseActualPercentageKey = "23.14453";
InstallPhasePercentageKey = 23;
May 17 16:03:32 Installer Progress[104]: IASSetCurrentInstallPhase: Current phase name set to "IOKit Boot"
May 17 16:03:32 Installer Progress[104]: totalPercentage = 23.144531
May 17 16:03:32 Installer Progress[104]: currentPhase = "<IASPPhase: 0x6000032dfa00: 'IOKit Boot', percentage 23.1, delay 0>", phases = (
"<IASPPhase: 0x6000032dfa60: 'loginwindow Boot', percentage 76.9, delay -1>"
ConclusionDelay = "-1";
InstallPhase = "loginwindow Boot";
InstallPhaseActualPercentageKey = "76.85547";
InstallPhasePercentageKey = 77;
May 17 16:03:32 Installer Progress[104]: Register process 146, phaseName loginwindow Boot, uuid BA41C2FA-9A70-4C45-9623-7AAC420DBA55
May 17 16:03:32 Installer Progress[104]: Connected processes {
"BA41C2FA-9A70-4C45-9623-7AAC420DBA55" = {
"Process ID" = 146;
UUID = "BA41C2FA-9A70-4C45-9623-7AAC420DBA55";
May 17 16:03:32 Installer Progress[104]: Saving completion handler for phase loginwindow Boot
CompletionHandlerKey = "<__NSMallocBlock__: 0x6000011f4320>";
"Process ID" = 146;
May 17 16:03:32 Installer Progress[104]: Register process 146, phaseName IOKit Boot, uuid C1BE032F-2480-40BB-A6BF-73FED123B787
"Process ID" = 146;
"C1BE032F-2480-40BB-A6BF-73FED123B787" = {
"Process ID" = 146;
UUID = "C1BE032F-2480-40BB-A6BF-73FED123B787";
May 17 16:03:32 Installer Progress[104]: Saving completion handler for phase IOKit Boot
"Process ID" = 146;
CompletionHandlerKey = "<__NSMallocBlock__: 0x6000011f1310>";
"Process ID" = 146;
May 17 16:03:32 Installer Progress[104]: Progress Updated: currentPhase = "IOKit Boot", phase progress = 100.000, total progress = 23.145
May 17 16:03:32 Installer Progress[104]: IASGetCurrentInstallPhaseList: phases = (
InstallPhaseActualPercentageKey = "23.14453125";
InstallPhaseActualPercentageKey = "76.85546875";
May 17 16:03:32 Installer Progress[104]: IASGetCurrentInstallPhase: Current phase name is "IOKit Boot"
May 17 16:03:32 Installer Progress[104]: Advance to phase named = "IOKit Boot"
May 17 16:03:32 Installer Progress[104]: currentPhase = "<IASPPhase: 0x6000032f8120: 'IOKit Boot', percentage 23.1, delay 0>", phases = (
"<IASPPhase: 0x6000032f8180: 'loginwindow Boot', percentage 76.9, delay -1>"
May 17 16:03:32 Installer Progress[104]: Showing Progress UI
May 17 16:03:32 Installer Progress[104]: HotKeys disabled
May 17 16:03:32 Installer Progress[104]: Progress app set to foreground app
May 17 16:03:32 Installer Progress[104]: _LSSetMetaApplicationInformationItem add to frontmost list success
May 17 16:03:32 Installer Progress[104]: Showing the windows
May 17 16:03:32 Installer Progress[104]: There are 0 window(s) and 1 display(s), 1 window(s) will be added
May 17 16:03:33 Installer Progress[104]: Created a window at {{0, 0}, {960, 540}}
May 17 16:03:33 Installer Progress[104]: Adding Apple Logo
May 17 16:03:33 Installer Progress[104]: Apple logo view created
May 17 16:03:33 Installer Progress[104]: Status is ""
May 17 16:03:33 Installer Progress[104]: Alternate status is ""
May 17 16:03:33 Installer Progress[104]: no background for progress added because:
May 17 16:03:33 Installer Progress[104]: no boot window list
May 17 16:03:33 Installer Progress[104]: IASPIsUsingFileVault NO
May 17 16:03:33 Installer Progress[104]: IASPGetBootMode Standard
May 17 16:03:33 Installer Progress[104]: and / or NOT booting from EFI loginwindow
May 17 16:03:33 Installer Progress[104]: _ShowUnmanagedSpace: aa403: Showing Unmanaged Space 2
May 17 16:03:33 Installer Progress[104]: Setting window alpha values to 1.0
May 17 16:03:33 Installer Progress[104]: Ordering windows front
May 17 16:03:33 Installer Progress[104]: Created CG Shield Window
May 17 16:03:33 Installer Progress[104]: Enable the display of progress windows
May 17 16:03:33 Installer Progress[104]: Using AppKit display change notification
May 17 16:03:33 Installer Progress[104]: Done with phase = "IOKit Boot"
May 17 16:03:33 Installer Progress[104]: Progress Updated: currentPhase = "IOKit Boot", phase progress = 100.000, total progress = 23.145
May 17 16:03:33 Installer Progress[104]: IASSetCurrentInstallPhase: Current phase name set to "loginwindow Boot"
May 17 16:03:33 Installer Progress[104]: Saving completion handler for phase IOKit Boot
May 17 16:03:33 Installer Progress[104]: Connected processes {
"Process ID" = 146;
CompletionHandlerKey = "<__NSMallocBlock__: 0x6000011f0fa0>";
"Process ID" = 146;
May 17 16:03:33 Installer Progress[104]: Unregister process 146, phaseName IOKit Boot, uuid C1BE032F-2480-40BB-A6BF-73FED123B787
"Process ID" = 146;
May 17 16:03:33 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 10.000, total progress = 30.830
May 17 16:03:33 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 30.000, total progress = 46.201
May 17 16:03:33 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 55.000, total progress = 65.415
May 17 16:03:33 loginwindow[146]: USER_PROCESS: 146 console
May 17 16:03:34 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 80.000, total progress = 84.629
May 17 16:03:34 Installer Progress[104]: Moving window from {{0, 0}, {960, 540}} to {{0, 0}, {1920, 1080}}
May 17 16:03:34 Installer Progress[104]: Setting window alpha values to 1.0
May 17 16:03:34 --- last message repeated 1 time ---
May 17 16:03:34 loginwindow[146]: client 0x600002e39200: phaseName = "loginwindow Boot" is done
May 17 16:03:34 loginwindow[146]: ISAP: Done with Phase "loginwindow Boot"
May 17 16:03:34 Installer Progress[104]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 100.000, total progress = 100.000
May 17 16:03:34 Installer Progress[104]: Done with phase = "loginwindow Boot"
May 17 16:03:34 Installer Progress[104]: IASClearInstallProgress: Clearing Registry
May 17 16:03:35 Installer Progress[104]: Ignoring the progress update because "loginwindow Boot" isn't one of the phases (null)
May 17 16:03:35 Installer Progress[104]: Calling animation completion handler
May 17 16:03:35 Installer Progress[104]: Progress complete, notifying registered clients
May 17 16:03:35 Installer Progress[104]: Calling completion handler for phase "loginwindow Boot"
May 17 16:03:35 loginwindow[146]: Calling completion handler for 0x600002e39200
May 17 16:03:35 loginwindow[146]: client 0x600002e39200: phaseName = "loginwindow Boot", hide progress UI called
May 17 16:03:35 loginwindow[146]: ISAP: hide progress UI called
May 17 16:03:35 loginwindow[146]: client 0x600002e39200: phaseName = "loginwindow Boot" is being released
May 17 16:03:35 Installer Progress[104]: Hiding Progress UI
May 17 16:03:35 loginwindow[146]: Releasing Connection
May 17 16:03:35 Installer Progress[104]: Showing the cursor in Progress UI
May 17 16:03:35 Installer Progress[104]: GUI session is logged in
May 17 16:03:35 Installer Progress[104]: Order Out CG Shield Window
May 17 16:03:35 Installer Progress[104]: Setting window alpha values to 0.0
May 17 16:03:35 Installer Progress[104]: Progress app removed from the frontmost only list
May 17 16:03:35 Installer Progress[104]: Progress app set to Background only app
May 17 16:03:35 Installer Progress[104]: HotKeys enabled
May 17 16:03:35 Installer Progress[104]: Start quit timer, will attempt to quit in 5 second(s) at 4:03:40 PM
May 17 16:03:35 Installer Progress[104]: Saving completion handler for phase loginwindow Boot
May 17 16:03:35 Installer Progress[104]: Will attempt to bring the Finder forward
May 17 16:03:35 Installer Progress[104]: Connected processes {
CompletionHandlerKey = "<__NSMallocBlock__: 0x6000011f8fa0>";
"Process ID" = 146;
May 17 16:03:35 Installer Progress[104]: Unregister process 146, phaseName loginwindow Boot, uuid BA41C2FA-9A70-4C45-9623-7AAC420DBA55
May 17 16:03:35 Installer Progress[104]: Activated application <NSRunningApplication: 0x600001cc4000 (com.apple.finder - 355) LSASN:{hi=0x0;lo=0x10010}>
May 17 16:03:36 Installer Progress[104]: Ordering windows out
May 17 16:03:37 Installer Progress[104]: There is no animation completion handler to call
May 17 16:03:40 Installer Progress[104]: Quitting because there are no phases. There are no connected processes. The UI is not showing.
May 17 16:03:40 Installer Progress[104]: Quitting Progress App
May 17 16:03:40 Installer Progress[104]: Showing the cursor in Progress UI
May 17 16:03:40 Installer Progress[104]: GUI session is logged in
May 17 16:03:40 Installer Progress[104]: Order Out CG Shield Window
May 17 16:03:40 Installer Progress[104]: Setting window alpha values to 0.0
May 17 16:03:40 loginwindow[146]: The connection was interrupted, calling interruption handlers
May 17 16:04:32 loginwindow[146]: There is still an active connection
May 17 16:05:05 --- last message repeated 1 time ---
May 17 16:05:40 sessionlogoutd[647]: DEAD_PROCESS: 146 console
May 17 16:05:40 shutdown[650]: SHUTDOWN_TIME: 1652821540 872632
May 17 16:05:51 localhost bootlog[0]: BOOT_TIME 1652821551 260223
May 17 16:05:55 localhost syslogd[107]: Configuration Notice:
May 17 16:05:55 localhost Installer Progress[104]: Progress UI App Starting
May 17 16:05:55 localhost syslogd[107]: ASL Sender Statistics
May 17 16:05:56 Installer Progress[104]: No boot windows available
May 17 16:05:56 Installer Progress[104]: Hiding the cursor in Progress UI
May 17 16:05:56 Installer Progress[104]: Configuration is deferred 1
May 17 16:05:57 loginwindow[145]: Clearing phase info
May 17 16:05:57 loginwindow[145]: calling progress app remoteObjectProxy
May 17 16:05:57 loginwindow[145]: Creating connection
May 17 16:05:57 loginwindow[145]: Connection = 0x600001ae4780, callers = (
"<IASUPCaller: 0x6000029e4720>"
May 17 16:05:57 Installer Progress[104]: caller = /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
May 17 16:05:57 Installer Progress[104]: Version 2
May 17 16:05:57 loginwindow[145]: version = 2
May 17 16:05:57 loginwindow[145]: isModernOS = 1
May 17 16:05:57 loginwindow[145]: Add phase named "IOKit Boot", progress 23.242188, delayInSeconds 0
May 17 16:05:57 Installer Progress[104]: Clearing phase info
May 17 16:05:57 loginwindow[145]: Add phase named "loginwindow Boot", progress 76.757812, delayInSeconds -1
May 17 16:05:57 Installer Progress[104]: IASGetCurrentInstallPhaseList: Unable to get phases
"<IASUPCaller: 0x6000029e4720>",
"<IASUPCaller: 0x6000029e87d0>"
Mac Studio M1 Ultra - System Log Part 4
