Deprecation Notice in ./vendor/twig/twig/src/Node/IncludeNode.php#25
Code: Select all
Backtrace
./vendor/composer/ClassLoader.php#444: include()
./vendor/composer/ClassLoader.php#322: Composer\Autoload\includeFile(string '/Library/Application Support/appsolute/MAMP PRO/phpMyAdmin/vendor/composer/../twig/twig/src/Node/IncludeNode.php')
./vendor/twig/twig/src/TokenParser/IncludeTokenParser.php#33: Composer\Autoload\ClassLoader->loadClass(string 'Twig\\Node\\IncludeNode')
./vendor/twig/twig/src/Parser.php#209: Twig\TokenParser\IncludeTokenParser->parse()
./vendor/twig/twig/src/TokenParser/ForTokenParser.php#51: Twig\Parser->subparse(array)
./vendor/twig/twig/src/Parser.php#209: Twig\TokenParser\ForTokenParser->parse()
./vendor/twig/twig/src/TokenParser/IfTokenParser.php#41: Twig\Parser->subparse(array)
./vendor/twig/twig/src/Parser.php#209: Twig\TokenParser\IfTokenParser->parse()
./vendor/twig/twig/src/Parser.php#122: Twig\Parser->subparse(
NULL,
boolean false,
./vendor/twig/twig/src/Environment.php#735: Twig\Parser->parse()
./vendor/twig/twig/src/Environment.php#793: Twig\Environment->parse()
./vendor/twig/twig/src/Environment.php#482: Twig\Environment->compileSource()
./vendor/twig/twig/src/Environment.php#445: Twig\Environment->loadClass(
string '__TwigTemplate_90e7b39835cdc945bc2cc586f171fd696393f183828babffe59b9369e68ba774',
string 'list/unordered.twig',
NULL,
./vendor/twig/twig/src/Environment.php#423: Twig\Environment->loadTemplate(string 'list/unordered.twig')
./libraries/classes/Template.php#115: Twig\Environment->load(string 'list/unordered.twig')
./libraries/classes/Config/FormDisplayTemplate.php#79: PhpMyAdmin\Template->render(array)
./libraries/classes/Config/FormDisplay.php#302: PhpMyAdmin\Config\FormDisplayTemplate::displayTabsTop(array)
./libraries/classes/Config/PageSettings.php#174: PhpMyAdmin\Config\FormDisplay->getDisplay(
boolean true,
boolean true,
boolean false,
string 'index.php?db=&table=&server=1&target=&lang=en',
array,
./libraries/classes/Config/PageSettings.php#93: PhpMyAdmin\Config\PageSettings->_getPageSettingsDisplay(
NULL,
./libraries/classes/Config/PageSettings.php#225: PhpMyAdmin\Config\PageSettings->__construct(
string 'Navi',
string 'pma_navigation_settings',
./libraries/classes/Navigation/Navigation.php#80: PhpMyAdmin\Config\PageSettings::getNaviSettings()
./libraries/classes/Header.php#440: PhpMyAdmin\Navigation\Navigation->getDisplay()
./libraries/classes/Response.php#266: PhpMyAdmin\Header->getDisplay()
./libraries/classes/Response.php#279: PhpMyAdmin\Response->_getDisplay()
./libraries/classes/Response.php#438: PhpMyAdmin\Response->_htmlResponse()
PhpMyAdmin\Response->response()
