Please update your Adobe password (Adobe Email)
Please update your Adobe password.
Dear Adobe Account Holder,
Your privacy is important to us and we are committed to being proactive when we detect events that might put your personal data at risk. To help protect your information, we have reset the password for the account associated with your Adobe ID that may have been compromised in data breaches from other online services. The next time you log into your Adobe account, you will be prompted with a password reset notice. If you have questions, please review our guidelines on Adobe.com for changing or resetting your password. Or, you can contact us.
In general, we recommend that you use different credentials on each website. You should take this opportunity to change your password on any websites where you used the same username or password as your Adobe ID. You can also enable Adobe’s two-factor authentication for your account to strengthen your account security. For more information on setting up two-factor authentication, please review our guidelines on Adobe.com.
Sincerely,
Adobe Customer Care
