Fix: Google - Verify It's You Just Spinning (YouTube App)
Update Fix: Until Google Resolves - On your mobile device where you are logged into the YouTube app, completely log out and remove your account. Then, re-login to Google in browser and it will default to the 2nd authentication method, most likely a text or call.
Trying to do the Google push verification from my YouTube app on my phone, but the YouTube app keeps spinning. No other ways to verify either....
Verify it’s you
To help keep your account safe, Google wants to make sure it’s really you
Open the YouTube app on iPhone
Google sent a notification to your iPhone. Open the YouTube app, tap Yes on the prompt, then tap XX on your phone to verify it’s you.
Google Verify Its You Spinning Broken
Google Verify Its You Spinning Broken (12.41 KiB) Viewed 49214 times
Re: Google - Verify It's You Just Spinning (YouTube App)
Post by Guest »
Same thing happening with me
Iamaguest
Re: Fix: Google - Verify It's You Just Spinning (YouTube App)
Post by Iamaguest »
Happening to me too, for two weeks now. I can't use the SMS option as I am overseas. Beyond frustrating!
I previously had issues with the Google Authenticator as it had to be deleted from my phone and there is no way to add it back without the QR code etc. etc. so that is not an option for me either.
Post by Guest »
Yes, the same thing is happening to me.
obbi13
Post by obbi13 »
Followed the "fix" still not working. After doing everything, google is not sending me any SMS on any of my registered phones. It used to work not anymore and I cannot access my account.
Post by Guest »
Getting the same issue. First time Google is lacking and letting everyone down... How do they not have this fixed yet.. sad
mikeabo61
Post by mikeabo61 »
just spins every time
You would think after awhile the spin would stop and come up with some kind of an error message.
space_hustle
Post by space_hustle »
This is how I fixed it:
1. Go to General->iPhone Storage->YouTube and click Delete App. You'll be asked whether or not you want to keep the subscription - I clicked Keep.
2. Go to App Store and reinstall YouTube app.
Post by Guest »
THIS JUST WORKED FOR ME
THANKS!
Post by Guest »
this just worked for me!! cant thank you enough :D
Post by Guest »
Please don't listen to this idiot like I did. Now I'm not even getting the notification to tap on Youtube to verify smfh.
gen ten
Post by gen ten »
i used the google mobile app and it worked.
