Fix: Unable to change owner and uid of webroot directory (Certbot Let's Encrypt)
Upon attempting to renew your domain SSL certificates, you receive an error message that prevents renewal:
Unable To Change Owner And Uid Of Webroot Diretory Certbot
Unable To Change Owner And Uid Of Webroot Diretory Certbot (4.95 KiB) Viewed 32097 times
1. Open the CONF file for the failing SSL renewal domains. For MAC, this is located in /etc/letsencrypt/renewal/SITE.conf
2. Scroll to
Code: Select all
[[webroot_map]]
and ensure your path directories are correct:
Code: Select all
site.com = /Users/sites/Sites/site.COM
www.site.com = /Users/sites/Sites/site.COM
