Your Notion application is not installed properly.
Your Notion Application Is Not Installed Properly
Your Notion Application Is Not Installed Properly (18.18 KiB) Viewed 1294 times
Invalid Install
Your Notion application is not installed properly. You need to move your Notion app into your Applications folder.
