Your Adobe app is not genuine (10-Day Grace Period Disable)
Your Adobe App Is Not Genuine
Your Adobe App Is Not Genuine (211.84 KiB) Viewed 2155 times
One or more of your Adobe apps is not genuine.
We're here to help with support and discounted replacement options.
Adobe provides victims of graud a 10-day grace period to resolve this issue with significant discounts on replacement apps. After the grace period ends, usage of your current non-genuine software will be blocked. Only genuine Adobe apps and services give you the latest features, functionality, and ongoing access to support, plus added protections from malware and viruses.
