macOS Big Sur 11.2.3 system.log part 1
16 localhost bootlog[0]: BOOT_TIME 1616770936 654937
22 localhost syslogd[65]: Configuration Notice:
ASL Module "com.apple.cdscheduler" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
ASL Module "com.apple.authd" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.contacts.ContactsAutocomplete" claims selected messages.
ASL Module "com.apple.mkb" sharing output destination "/private/var/log/keybagd.log" with ASL Module "com.apple.mkb.internal".
Output parameters from ASL Module "com.apple.mkb.internal" override any specified in ASL Module "com.apple.mkb".
ASL Module "com.apple.mkb" claims selected messages.
ASL Module "com.apple.AddressBookLegacy" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
ASL Module "com.apple.clouddocs" claims selected messages.
22 localhost com.apple.xpc.launchd[1]: launchd logging initialized
22 localhost com.apple.xpc.launchd[1]: Doing boot task: xpcroleaccountd
22 localhost com.apple.xpc.launchd[1]: Doing boot task: init_featureflags
22 localhost com.apple.xpc.launchd[1]: Doing boot task: EndpointSecurity
22 localhost com.apple.xpc.launchd[1]: Doing boot task: rc.server
22 localhost com.apple.xpc.launchd[1]: rc.server: optional boot task not present
22 localhost com.apple.xpc.launchd[1]: Doing boot task: tzinit
22 localhost com.apple.xpc.launchd[1]: Doing boot task: dirhelper
22 localhost com.apple.xpc.launchd[1]: Doing boot task: rootless-init
22 localhost com.apple.xpc.launchd[1]: Doing boot task: finish-demo-restore
22 localhost com.apple.xpc.launchd[1]: finish-demo-restore: optional boot task not present
22 localhost com.apple.xpc.launchd[1]: Doing boot task: systemstats
22 localhost com.apple.xpc.launchd[1]: Doing boot task: prng_seedctl
22 localhost Installer Progress[96]: Progress UI App Starting
22 localhost syslogd[65]: ASL Sender Statistics
23 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.0): entering bootstrap mode
23 localhost com.apple.xpc.launchd[1] (com.apple.distnoted.xpc.agent): This service is defined to be constantly running and is inherently inefficient.
23 localhost WindowServer[130]: DEPRECATED USE in libdispatch client: dispatch source activated with no event handler set; set a breakpoint on _dispatch_bug_deprecated to debug
23 localhost com.apple.xpc.launchd[1] (com.apple.lsd): Event stream com.apple.launchservices.LSObserver is already monitored by com.apple.lsd, ignoring
23 localhost com.apple.xpc.launchd[1] (com.apple.coreimportd): Unknown key for dictionary: NoEnvironmentVariables
23 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.0): exiting bootstrap mode
23 localhost com.apple.xpc.launchd[1] (com.apple.iomfb_fdr_loader[74]): Service exited with abnormal code: 1
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.ManagedClient.startup" tried to register for endpoint "com.apple.ManagedClient.agent" already registered by owner: com.apple.ManagedClient
23 m1air PowerUIAgent[167]: DEPRECATED USE in libdispatch client: dispatch source activated with no event handler set; set a breakpoint on _dispatch_bug_deprecated to debug
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): entering bootstrap mode
23 m1air com.apple.xpc.launchd[1] (com.apple.imklaunchagent): This service is defined to be constantly running and is inherently inefficient.
23 m1air com.apple.xpc.launchd[1] (com.apple.coreservices.UASharedPasteboardProgressUI): Unknown key for Boolean: DrainMessagesAfterFailedInit
23 m1air com.apple.xpc.launchd[1] (com.apple.UserEventAgent-LoginWindow): This service is defined to be constantly running and is inherently inefficient.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.universalaccessd (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.VoiceOver (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.accessibility.AXVisualSupportAgent (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.AskPermissionUI (lint): UserName is not supported for non-System services.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.AssistiveControl (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.DwellControl (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.universalaccesscontrol (lint): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
23 m1air com.apple.xpc.launchd[1] (com.apple.coreservices.useractivityd): Unknown key for Boolean: DrainMessagesAfterFailedInit
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): exiting bootstrap mode
23 m1air com.apple.xpc.launchd[1] (com.apple.iomfb_fdr_loader): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
23 m1air findmydeviced[193]: objc[193]: Class LocalizedUnregisterErrorKey is implemented in both /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice and /usr/libexec/findmydeviced. One of the two will be used. Which one is undefined.
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.88): entering bootstrap mode
23 m1air com.apple.xpc.launchd[1] (com.apple.distnoted.xpc.agent): This service is defined to be constantly running and is inherently inefficient.
23 m1air com.apple.xpc.launchd[1] (com.apple.lsd): Event stream com.apple.launchservices.LSObserver is already monitored by com.apple.lsd, ignoring
23 m1air com.apple.xpc.launchd[1] (com.apple.coreimportd): Unknown key for dictionary: NoEnvironmentVariables
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.88): exiting bootstrap mode
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.202): entering bootstrap mode
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.202): exiting bootstrap mode
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.205): entering bootstrap mode
23 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.205): exiting bootstrap mode
23 m1air com.apple.geod[235]: objc[235]: Class GEOETAProvider is implemented in both /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices and /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod. One of the two will be used. Which one is undefined.
24 m1air com.apple.xpc.launchd[1] (com.apple.wifiFirmwareLoader): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
24 m1air Installer Progress[96]: No boot windows available
24 m1air Installer Progress[96]: Hiding the cursor in Progress UI
24 m1air Installer Progress[96]: Configuration is deferred 1
24 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.ManagedClient.enroll" tried to register for endpoint "com.apple.ManagedClient.agent" already registered by owner: com.apple.ManagedClient
24 m1air bootinstalld[247]: getattrlist failed for /System/Volumes/Data/.com.apple.templatemigration.boot-install.plist: #2: No such file or directory
24 m1air loginwindow[132]: Clearing phase info
24 m1air loginwindow[132]: calling progress app remoteObjectProxy
24 m1air loginwindow[132]: Creating connection
24 m1air loginwindow[132]: Connection = 0x142610030, callers = (
"<IASUPCaller: 0x142768ec0>"
24 m1air Installer Progress[96]: caller = /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
24 m1air Installer Progress[96]: Version 2
24 m1air loginwindow[132]: version = 2
24 m1air loginwindow[132]: isModernOS = 1
24 m1air loginwindow[132]: Add phase named "IOKit Boot", progress 27.441406, delayInSeconds 0
24 m1air Installer Progress[96]: Clearing phase info
24 m1air loginwindow[132]: Add phase named "loginwindow Boot", progress 72.558594, delayInSeconds -1
24 m1air Installer Progress[96]: IASGetCurrentInstallPhaseList: Unable to get phases
"<IASUPCaller: 0x142768ec0>",
"<IASUPCaller: 0x1427648b0>"
24 m1air loginwindow[132]: client 0x1427672a0: phaseName = "loginwindow Boot", registering connection
24 m1air Installer Progress[96]: IASGetCurrentInstallPhase: Unable to get the current phase name
24 m1air Installer Progress[96]: Current phase name wasn't saved, using the first phase in the list, current phase = "(null)"
24 m1air Installer Progress[96]: currentPhase = "(null)", phases = (null)
24 m1air Installer Progress[96]: IASClearInstallProgress: Clearing Registry
24 m1air loginwindow[132]: client 0x1427672a0: phaseName = "loginwindow Boot" was created
"<IASUPCaller: 0x1427648b0>",
"<IASUPCaller: 0x142766090>"
24 m1air Installer Progress[96]: IASClearInstallProgress: can't clear phases property
24 m1air loginwindow[132]: client 0x142765f10: phaseName = "IOKit Boot", registering connection
24 m1air Installer Progress[96]: IASClearInstallProgress: can't clear current phase name property
24 m1air Installer Progress[96]: totalPercentage = 0.000000
24 m1air loginwindow[132]: client 0x142765f10: phaseName = "IOKit Boot" was created
"<IASPPhase: 0x600000a448c0: 'IOKit Boot', percentage 27.4, delay 0>"
24 m1air loginwindow[132]: client 0x142765f10: phaseName = "IOKit Boot", show progress UI called
24 m1air loginwindow[132]: ISAP: Show progress UI called
24 m1air loginwindow[132]: client 0x142765f10: phaseName = "IOKit Boot" is done
24 m1air loginwindow[132]: ISAP: Done with Phase "IOKit Boot"
24 m1air Installer Progress[96]: IASSetCurrentInstallPhaseList: phases set to (
ConclusionDelay = 0;
InstallPhase = "IOKit Boot";
InstallPhaseActualPercentageKey = "27.44141";
InstallPhasePercentageKey = 27;
24 m1air loginwindow[132]: client 0x142765f10: phaseName = "IOKit Boot" is being released
24 m1air loginwindow[132]: Releasing Connection
24 m1air Installer Progress[96]: IASSetCurrentInstallPhase: Current phase name set to "IOKit Boot"
24 m1air Installer Progress[96]: totalPercentage = 27.441406
24 m1air loginwindow[132]: client 0x1427672a0: handler = 0x16f8561a8
24 m1air Installer Progress[96]: currentPhase = "<IASPPhase: 0x600000a448c0: 'IOKit Boot', percentage 27.4, delay 0>", phases = (
"<IASPPhase: 0x600000a44f40: 'loginwindow Boot', percentage 72.6, delay -1>"
ConclusionDelay = "-1";
InstallPhase = "loginwindow Boot";
InstallPhaseActualPercentageKey = "72.55859";
InstallPhasePercentageKey = 73;
24 m1air Installer Progress[96]: Register process 132, phaseName loginwindow Boot, uuid E4F2DEFE-B860-4585-80DB-968EC5E3BC2A
24 m1air Installer Progress[96]: Connected processes {
"E4F2DEFE-B860-4585-80DB-968EC5E3BC2A" = {
"Phase Name" = "loginwindow Boot";
"Process ID" = 132;
UUID = "E4F2DEFE-B860-4585-80DB-968EC5E3BC2A";
24 m1air Installer Progress[96]: Saving completion handler for phase loginwindow Boot
CompletionHandlerKey = "<__NSMallocBlock__: 0x6000029782d0>";
"Process ID" = 132;
24 m1air Installer Progress[96]: Register process 132, phaseName IOKit Boot, uuid 5C7232CB-1C2B-4DF3-8B6B-0B08716A2C08
"5C7232CB-1C2B-4DF3-8B6B-0B08716A2C08" = {
"Phase Name" = "IOKit Boot";
"Process ID" = 132;
UUID = "5C7232CB-1C2B-4DF3-8B6B-0B08716A2C08";
"Process ID" = 132;
24 m1air Installer Progress[96]: Saving completion handler for phase IOKit Boot
CompletionHandlerKey = "<__NSMallocBlock__: 0x60000295f9d0>";
"Process ID" = 132;
"Process ID" = 132;
24 m1air Installer Progress[96]: Progress Updated: currentPhase = "IOKit Boot", phase progress = 100.000, total progress = 27.441
24 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.132.4294967295): com.apple.package-script-service (lint): JoinExistingSession is only available to Application services.
24 m1air Installer Progress[96]: Progress app is loading…
24 m1air Installer Progress[96]: Progress app is running…
24 m1air Installer Progress[96]: IASGetCurrentInstallPhaseList: phases = (
InstallPhaseActualPercentageKey = "27.44140625";
InstallPhaseActualPercentageKey = "72.55859375";
24 m1air Installer Progress[96]: IASGetCurrentInstallPhase: Current phase name is "IOKit Boot"
24 m1air Installer Progress[96]: Advance to phase named = "IOKit Boot"
24 m1air Installer Progress[96]: currentPhase = "<IASPPhase: 0x600000a531e0: 'IOKit Boot', percentage 27.4, delay 0>", phases = (
"<IASPPhase: 0x600000a53300: 'loginwindow Boot', percentage 72.6, delay -1>"
24 m1air Installer Progress[96]: Showing Progress UI
24 m1air Installer Progress[96]: _LSSetMetaApplicationInformationItem add to frontmost list success
24 m1air Installer Progress[96]: Showing the windows
24 m1air Installer Progress[96]: There are 0 window(s) and 1 display(s), 1 window(s) will be added
24 m1air com.apple.xpc.launchd[1] (com.apple.bsd.dirhelper[119]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.bsd.dirhelper
24 m1air Installer Progress[96]: Created a window at {{0, 0}, {1280, 800}}
24 m1air Installer Progress[96]: Adding Apple Logo
24 m1air Installer Progress[96]: Apple logo view created
24 m1air Installer Progress[96]: Status is ""
24 m1air Installer Progress[96]: Alternate status is ""
24 m1air Installer Progress[96]: no background for progress added because:
24 m1air Installer Progress[96]: no boot window list
24 m1air Installer Progress[96]: IASPIsUsingFileVault NO
24 m1air Installer Progress[96]: IASPGetBootMode Standard
24 m1air Installer Progress[96]: and / or NOT booting from EFI loginwindow
24 m1air Installer Progress[96]: _ShowUnmanagedSpace: 5040f: Showing Unmanaged Space 2
24 m1air Installer Progress[96]: Setting window alpha values to 1.0
24 m1air Installer Progress[96]: Ordering windows front
24 m1air Installer Progress[96]: Created CG Shield Window
24 m1air Installer Progress[96]: Enable the display of progress windows
24 m1air Installer Progress[96]: Using AppKit display change notification
24 m1air Installer Progress[96]: Done with phase = "IOKit Boot"
24 m1air Installer Progress[96]: IASSetCurrentInstallPhase: Current phase name set to "loginwindow Boot"
CompletionHandlerKey = "<__NSMallocBlock__: 0x60000295fa70>";
"Process ID" = 132;
"Process ID" = 132;
24 m1air Installer Progress[96]: Unregister process 132, phaseName IOKit Boot, uuid 5C7232CB-1C2B-4DF3-8B6B-0B08716A2C08
"Process ID" = 132;
24 m1air Installer Progress[96]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 10.000, total progress = 34.697
24 m1air Installer Progress[96]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 25.000, total progress = 45.581
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/TrustedPeersHelper.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/ColorSampler.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.250): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.92): entering bootstrap mode
25 m1air com.apple.xpc.launchd[1] (com.apple.distnoted.xpc.agent): This service is defined to be constantly running and is inherently inefficient.
25 m1air com.apple.xpc.launchd[1] (com.apple.lsd): Event stream com.apple.launchservices.LSObserver is already monitored by com.apple.lsd, ignoring
25 m1air com.apple.xpc.launchd[1] (com.apple.coreimportd): Unknown key for dictionary: NoEnvironmentVariables
25 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.92): exiting bootstrap mode
25 m1air VTDecoderXPCService[280]: DEPRECATED USE in libdispatch client: Changing the target of a source after it has been activated; set a breakpoint on _dispatch_bug_deprecated to debug
25 m1air backupd[283]: DEPRECATED USE in libdispatch client: dispatch source activated with no event handler set; set a breakpoint on _dispatch_bug_deprecated to debug
25 m1air VTDecoderXPCService[280]: DEPRECATED USE in libdispatch client: Changing target queue hierarchy after xpc connection was activated; set a breakpoint on _dispatch_bug_deprecated to debug
25 m1air syspolicyd[285]: objc[285]: Class StagedBundleData is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class MIS is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class AppWrapper is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class PolicyCacheMeta is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class AppWrapperPolicyResult is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class AppWrapperPolicy is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class ValidationProgress is implemented in both /usr/lib/libmis.dylib and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class SPLog is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class AKELData is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class PolicyScanTarget is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class BundleData is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class SPMigrationScanner is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air syspolicyd[285]: objc[285]: Class SPExecutionHistoryItem is implemented in both /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy and /usr/libexec/syspolicyd. One of the two will be used. Which one is undefined.
25 m1air fud[84]: objc[84]: Class AMSupportURLConnectionDelegate is implemented in both /usr/lib/libamsupport.dylib and /System/Library/PrivateFrameworks/MobileAccessoryUpdater.framework/Support/fud. One of the two will be used. Which one is undefined.
25 m1air fud[84]: objc[84]: Class AMSupportURLSession is implemented in both /usr/lib/libamsupport.dylib and /System/Library/PrivateFrameworks/MobileAccessoryUpdater.framework/Support/fud. One of the two will be used. Which one is undefined.
25 m1air PerfPowerServices[118]: assertion failed: 20D91: PowerlogCore + 769284 [25472DCA-6393-30A3-9C8C-E6788763BF00]: 0x3
25 m1air coreauthd[294]: objc[294]: Class OwnerInfo is implemented in both /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd (0x104b6cc58) and /System/Library/Frameworks/LocalAuthentication.framework/Support/ModulePlugins/ModuleACM.bundle/Contents/MacOS/ModuleACM (0x104c3db60). One of the two will be used. Which one is undefined.
25 m1air coreauthd[294]: objc[294]: Class OwnerInfos is implemented in both /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd (0x104b6cca8) and /System/Library/Frameworks/LocalAuthentication.framework/Support/ModulePlugins/ModuleACM.bundle/Contents/MacOS/ModuleACM (0x104c3dbb0). One of the two will be used. Which one is undefined.
25 m1air loginwindow[132]: client 0x1427672a0: phaseName = "loginwindow Boot" is done
25 m1air loginwindow[132]: ISAP: Done with Phase "loginwindow Boot"
25 m1air Installer Progress[96]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 100.000, total progress = 100.000
25 m1air Installer Progress[96]: Done with phase = "loginwindow Boot"
25 m1air Installer Progress[96]: IASClearInstallProgress: Clearing Registry
25 m1air airportd[197]: DEPRECATED USE in libdispatch client: dispatch source activated with no event handler set; set a breakpoint on _dispatch_bug_deprecated to debug
26 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.89): entering bootstrap mode
26 m1air com.apple.xpc.launchd[1] (com.apple.distnoted.xpc.agent): This service is defined to be constantly running and is inherently inefficient.
26 m1air com.apple.xpc.launchd[1] (com.apple.lsd): Event stream com.apple.launchservices.LSObserver is already monitored by com.apple.lsd, ignoring
26 m1air com.apple.xpc.launchd[1] (com.apple.coreimportd): Unknown key for dictionary: NoEnvironmentVariables
26 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.89): exiting bootstrap mode
26 m1air systemstats[73]: DEPRECATED USE in libdispatch client: dispatch source activated with no event handler set; set a breakpoint on _dispatch_bug_deprecated to debug
26 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.200): entering bootstrap mode
26 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.200): exiting bootstrap mode
26 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.0): com.apple.package-script-service (lint): JoinExistingSession is only available to Application services.
26 m1air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.200): com.apple.package-script-service (lint): JoinExistingSession is only available to Application services.
26 m1air suhelperd[311]: objc[311]: Class SUReachabilityMonitor is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd. One of the two will be used. Which one is undefined.
26 m1air suhelperd[311]: objc[311]: Class SUPrinterScan is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd. One of the two will be used. Which one is undefined.
26 m1air suhelperd[311]: objc[311]: Class SUSignedFlatPkg is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd. One of the two will be used. Which one is undefined.
26 m1air suhelperd[311]: objc[311]: Class SUPowerAssertionManager is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd. One of the two will be used. Which one is undefined.
26 m1air suhelperd[311]: objc[311]: Class SUPowerSourceMonitor is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd. One of the two will be used. Which one is undefined.
26 m1air suhelperd[311]: objc[311]: Class SUURLConnection is implemented in both /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd. One of the two will be used. Which one is undefined.
26 m1air suhelperd[311]: objc[311]: Class KeychainMasterHandler is implemented in both /usr/lib/libIASAuthReboot.dylib and /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd. One of the two will be used. Which one is undefined.
26 m1air ReportCrash[301]: objc[301]: Class CrashReport is implemented in both /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport and /System/Library/CoreServices/ReportCrash. One of the two will be used. Which one is undefined.
26 m1air Installer Progress[96]: Calling animation completion handler
26 m1air Installer Progress[96]: Progress complete, notifying registered clients
26 m1air Installer Progress[96]: Calling completion handler for phase "loginwindow Boot"
26 m1air loginwindow[132]: Calling completion handler for 0x1427672a0
26 m1air loginwindow[132]: client 0x1427672a0: phaseName = "loginwindow Boot", hide progress UI called
26 m1air loginwindow[132]: ISAP: hide progress UI called
26 m1air loginwindow[132]: client 0x1427672a0: phaseName = "loginwindow Boot" is being released
26 m1air Installer Progress[96]: Hiding Progress UI
26 m1air loginwindow[132]: Releasing Connection
26 m1air Installer Progress[96]: Showing the cursor in Progress UI
26 m1air Installer Progress[96]: GUI session is not logged in
26 m1air Installer Progress[96]: Setting window alpha values to 0.0
26 m1air Installer Progress[96]: Ordering windows out
26 m1air Installer Progress[96]: Performing deferred configuration
26 m1air Installer Progress[96]: _LSSetMetaApplicationInformationItem remove from frontmost list success
26 m1air Installer Progress[96]: Start quit timer, will attempt to quit in 5 second(s) at31 AM
26 m1air Installer Progress[96]: Saving completion handler for phase loginwindow Boot
26 m1air Installer Progress[96]: Connected processes {
CompletionHandlerKey = "<__NSMallocBlock__: 0x60000294c870>";
"Process ID" = 132;
26 m1air Installer Progress[96]: Unregister process 132, phaseName loginwindow Boot, uuid E4F2DEFE-B860-4585-80DB-968EC5E3BC2A
kmesiab
Re: macOS Big Sur 11.2.3 system.log part 1
Post by kmesiab »
Looks like the same rootkit i'm dealing with now.
Tikker
Post by Tikker »
macOS Monterrey 12.3.1 System Log of Persistant " IOBoot kit "
May 13 00:35:14 MacBook-Air syslogd[275]: Configuration Notice:
May 13 00:35:14 MacBook-Air Installer Progress[272]: Progress UI App Starting
May 13 00:35:14 MacBook-Air syslogd[275]: ASL Sender Statistics
May 13 00:35:19 MacBook-Air Installer Progress[272]: No boot windows available
May 13 00:35:19 MacBook-Air Installer Progress[272]: Hiding the cursor in Progress UI
May 13 00:35:19 MacBook-Air Installer Progress[272]: Configuration is deferred 1
May 13 00:35:19 MacBook-Air loginwindow[312]: Clearing phase info
May 13 00:35:19 MacBook-Air loginwindow[312]: calling progress app remoteObjectProxy
May 13 00:35:19 MacBook-Air loginwindow[312]: Creating connection
May 13 00:35:19 MacBook-Air loginwindow[312]: Connection = 0x600001624640, callers = (
"<IASUPCaller: 0x6000025290e0>"
May 13 00:35:19 MacBook-Air Installer Progress[272]: caller = /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
May 13 00:35:19 MacBook-Air Installer Progress[272]: Version 2
May 13 00:35:19 MacBook-Air loginwindow[312]: version = 2
May 13 00:35:19 MacBook-Air loginwindow[312]: isModernOS = 1
May 13 00:35:19 MacBook-Air loginwindow[312]: Add phase named "IOKit Boot", progress 25.683594, delayInSeconds 0
May 13 00:35:19 MacBook-Air Installer Progress[272]: Clearing phase info
May 13 00:35:19 MacBook-Air loginwindow[312]: Add phase named "loginwindow Boot", progress 74.316406, delayInSeconds -1
"<IASUPCaller: 0x6000025290e0>",
"<IASUPCaller: 0x600002530450>"
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322da00: phaseName = "loginwindow Boot", registering connection
May 13 00:35:19 MacBook-Air Installer Progress[272]: IASGetCurrentInstallPhaseList: phases = (
InstallPhase = "Boot 1";
InstallPhaseActualPercentageKey = "25.68359375";
InstallPhasePercentageKey = 26;
InstallPhase = "Language Chooser";
InstallPhaseActualPercentageKey = "74.31640625";
InstallPhasePercentageKey = 74;
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322da00: phaseName = "loginwindow Boot" was created
"<IASUPCaller: 0x600002530450>",
"<IASUPCaller: 0x600002530460>"
May 13 00:35:19 MacBook-Air Installer Progress[272]: IASGetCurrentInstallPhase: Current phase name is "Boot 1"
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322d8c0: phaseName = "IOKit Boot", registering connection
May 13 00:35:19 MacBook-Air Installer Progress[272]: Advance to phase named = "Boot 1"
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322d8c0: phaseName = "IOKit Boot" was created
May 13 00:35:19 MacBook-Air Installer Progress[272]: currentPhase = "<IASPPhase: 0x60000284c020: 'Boot 1', percentage 25.7, delay 0>", phases = (
"<IASPPhase: 0x60000284c040: 'Language Chooser', percentage 74.3, delay 0>"
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322d8c0: phaseName = "IOKit Boot", show progress UI called
May 13 00:35:19 MacBook-Air Installer Progress[272]: IASClearInstallProgress: Clearing Registry
May 13 00:35:19 MacBook-Air loginwindow[312]: ISAP: Show progress UI called
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322d8c0: phaseName = "IOKit Boot" is done
May 13 00:35:19 MacBook-Air loginwindow[312]: ISAP: Done with Phase "IOKit Boot"
May 13 00:35:19 MacBook-Air Installer Progress[272]: totalPercentage = 0.000000
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322d8c0: phaseName = "IOKit Boot" is being released
May 13 00:35:19 MacBook-Air Installer Progress[272]: currentPhase = "(null)", phases = (
"<IASPPhase: 0x60000286e0a0: 'IOKit Boot', percentage 25.7, delay 0>"
May 13 00:35:19 MacBook-Air loginwindow[312]: Releasing Connection
May 13 00:35:19 MacBook-Air Installer Progress[272]: IASSetCurrentInstallPhaseList: phases set to (
InstallPhaseActualPercentageKey = "25.68359";
May 13 00:35:19 MacBook-Air loginwindow[312]: client 0x60000322da00: handler = 0x16f856008
May 13 00:35:19 MacBook-Air Installer Progress[272]: IASSetCurrentInstallPhase: Current phase name set to "IOKit Boot"
May 13 00:35:19 MacBook-Air Installer Progress[272]: totalPercentage = 25.683594
May 13 00:35:19 MacBook-Air Installer Progress[272]: currentPhase = "<IASPPhase: 0x60000286e0a0: 'IOKit Boot', percentage 25.7, delay 0>", phases = (
"<IASPPhase: 0x60000286e100: 'loginwindow Boot', percentage 74.3, delay -1>"
InstallPhaseActualPercentageKey = "74.31641";
May 13 00:35:19 MacBook-Air Installer Progress[272]: Register process 312, phaseName loginwindow Boot, uuid FBD767B1-4D4F-4500-BFA6-AE50C6451810
May 13 00:35:19 MacBook-Air Installer Progress[272]: Connected processes {
"FBD767B1-4D4F-4500-BFA6-AE50C6451810" = {
"Process ID" = 312;
UUID = "FBD767B1-4D4F-4500-BFA6-AE50C6451810";
May 13 00:35:19 MacBook-Air Installer Progress[272]: Saving completion handler for phase loginwindow Boot
CompletionHandlerKey = "<__NSMallocBlock__: 0x600000b60870>";
"Process ID" = 312;
May 13 00:35:19 MacBook-Air Installer Progress[272]: Register process 312, phaseName IOKit Boot, uuid 4913E394-8880-4C9C-BD91-49C6C3090694
"4913E394-8880-4C9C-BD91-49C6C3090694" = {
"Process ID" = 312;
UUID = "4913E394-8880-4C9C-BD91-49C6C3090694";
"Process ID" = 312;
May 13 00:35:19 MacBook-Air Installer Progress[272]: Saving completion handler for phase IOKit Boot
CompletionHandlerKey = "<__NSMallocBlock__: 0x600000b48af0>";
"Process ID" = 312;
"Process ID" = 312;
May 13 00:35:19 MacBook-Air Installer Progress[272]: Progress Updated: currentPhase = "IOKit Boot", phase progress = 100.000, total progress = 25.684
May 13 00:35:19 MacBook-Air loginwindow[312]: USER_PROCESS: 312 console
May 13 00:35:19 MacBook-Air Installer Progress[272]: Progress app is loading…
May 13 00:35:19 MacBook-Air Installer Progress[272]: Progress app is running…
May 13 00:35:19 MacBook-Air Installer Progress[272]: IASGetCurrentInstallPhase: Current phase name is "IOKit Boot"
May 13 00:35:19 MacBook-Air Installer Progress[272]: Advance to phase named = "IOKit Boot"
May 13 00:35:19 MacBook-Air Installer Progress[272]: currentPhase = "<IASPPhase: 0x60000286e200: 'IOKit Boot', percentage 25.7, delay 0>", phases = (
"<IASPPhase: 0x60000286e160: 'loginwindow Boot', percentage 74.3, delay -1>"
May 13 00:35:19 MacBook-Air Installer Progress[272]: Showing Progress UI
May 13 00:35:19 MacBook-Air Installer Progress[272]: HotKeys disabled
May 13 00:35:19 MacBook-Air Installer Progress[272]: Progress app set to foreground app
May 13 00:35:19 MacBook-Air Installer Progress[272]: _LSSetMetaApplicationInformationItem add to frontmost list success
May 13 00:35:19 MacBook-Air Installer Progress[272]: Showing the windows
May 13 00:35:19 MacBook-Air Installer Progress[272]: There are 0 window(s) and 1 display(s), 1 window(s) will be added
May 13 00:35:20 MacBook-Air Installer Progress[272]: Created a window at {{0, 0}, {1280, 800}}
May 13 00:35:20 MacBook-Air Installer Progress[272]: Adding Apple Logo
May 13 00:35:20 MacBook-Air Installer Progress[272]: Apple logo view created
May 13 00:35:20 MacBook-Air Installer Progress[272]: Status is ""
May 13 00:35:20 MacBook-Air Installer Progress[272]: Alternate status is ""
May 13 00:35:20 MacBook-Air Installer Progress[272]: no background for progress added because:
May 13 00:35:20 MacBook-Air Installer Progress[272]: no boot window list
May 13 00:35:20 MacBook-Air Installer Progress[272]: IASPIsUsingFileVault NO
May 13 00:35:20 MacBook-Air Installer Progress[272]: IASPGetBootMode Standard
May 13 00:35:20 MacBook-Air Installer Progress[272]: and / or NOT booting from EFI loginwindow
May 13 00:35:20 MacBook-Air Installer Progress[272]: _ShowUnmanagedSpace: 34c07: Showing Unmanaged Space 2
May 13 00:35:20 MacBook-Air Installer Progress[272]: Setting window alpha values to 1.0
May 13 00:35:20 MacBook-Air Installer Progress[272]: Ordering windows front
May 13 00:35:20 MacBook-Air Installer Progress[272]: Created CG Shield Window
May 13 00:35:20 MacBook-Air Installer Progress[272]: Enable the display of progress windows
May 13 00:35:20 MacBook-Air Installer Progress[272]: Using AppKit display change notification
May 13 00:35:20 MacBook-Air Installer Progress[272]: Done with phase = "IOKit Boot"
May 13 00:35:20 MacBook-Air Installer Progress[272]: Progress Updated: currentPhase = "IOKit Boot", phase progress = 100.000, total progress = 25.684
May 13 00:35:20 MacBook-Air Installer Progress[272]: IASSetCurrentInstallPhase: Current phase name set to "loginwindow Boot"
May 13 00:35:20 MacBook-Air Installer Progress[272]: Saving completion handler for phase IOKit Boot
May 13 00:35:20 MacBook-Air Installer Progress[272]: Connected processes {
CompletionHandlerKey = "<__NSMallocBlock__: 0x600000b79220>";
"Process ID" = 312;
"Process ID" = 312;
May 13 00:35:20 MacBook-Air Installer Progress[272]: Unregister process 312, phaseName IOKit Boot, uuid 4913E394-8880-4C9C-BD91-49C6C3090694
"Process ID" = 312;
May 13 00:35:20 MacBook-Air Installer Progress[272]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 10.000, total progress = 33.115
May 13 00:35:20 MacBook-Air Installer Progress[272]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 60.000, total progress = 70.273
May 13 00:35:21 MacBook-Air loginwindow[312]: DEAD_PROCESS: 312 console
May 13 00:35:23 MacBook-Air Installer Progress[272]: Progress Updated: currentPhase = "loginwindow Boot", phase progress = 85.000, total progress = 88.853
May 13 00:35:23 MacBook-Air loginwindow[312]: client 0x60000322da00: phaseName = "loginwindow Boot", hide progress UI called
May 13 00:35:23 MacBook-Air loginwindow[312]: ISAP: hide progress UI called
May 13 00:35:23 MacBook-Air loginwindow[312]: client 0x60000322da00: phaseName = "loginwindow Boot" is being released
May 13 00:35:23 MacBook-Air loginwindow[312]: Releasing Connection
May 13 00:35:23 MacBook-Air Installer Progress[272]: Hiding Progress UI
May 13 00:35:23 MacBook-Air Installer Progress[272]: Showing the cursor in Progress UI
May 13 00:35:23 MacBook-Air Installer Progress[272]: GUI session is not logged in
May 13 00:35:23 MacBook-Air Installer Progress[272]: Setting window alpha values to 0.0
May 13 00:35:23 MacBook-Air Installer Progress[272]: Ordering windows out
May 13 00:35:23 MacBook-Air Installer Progress[272]: Performing deferred configuration
May 13 00:35:23 MacBook-Air Installer Progress[272]: Progress app removed from the frontmost only list
May 13 00:35:23 MacBook-Air Installer Progress[272]: Progress app set to Background only app
May 13 00:35:23 MacBook-Air Installer Progress[272]: HotKeys enabled
May 13 00:35:23 MacBook-Air loginwindow[312]: USER_PROCESS: 312 console
May 13 00:35:23 MacBook-Air Installer Progress[272]: Start quit timer, will attempt to quit in 5 second(s) at 12:35:28 AM
May 13 00:35:23 MacBook-Air Installer Progress[272]: Saving completion handler for phase loginwindow Boot
May 13 00:35:23 MacBook-Air Installer Progress[272]: Connected processes {
CompletionHandlerKey = "<__NSMallocBlock__: 0x600000b7c5a0>";
"Process ID" = 312;
May 13 00:35:23 MacBook-Air Installer Progress[272]: Unregister process 312, phaseName loginwindow Boot, uuid FBD767B1-4D4F-4500-BFA6-AE50C6451810
May 13 00:35:23 MacBook-Air Installer Progress[272]: Finder is not running
May 13 00:35:23 MacBook-Air Installer Progress[272]: No application to bring forward
May 13 00:35:23 MacBook-Air Setup Assistant[606]: Creating connection
May 13 00:35:23 MacBook-Air Setup Assistant[606]: Connection = 0x600003d19f40, callers = (
"<IASUPCaller: 0x600000e143a0>"
May 13 00:35:23 MacBook-Air Setup Assistant[606]: client 0x60000191e3c0: phaseName = "Setup Assistant", registering connection
May 13 00:35:23 MacBook-Air Setup Assistant[606]: client 0x60000191e3c0: phaseName = "Setup Assistant" was created
May 13 00:35:23 MacBook-Air Setup Assistant[606]: client 0x60000191e3c0: phaseName = "Setup Assistant" is done
May 13 00:35:23 MacBook-Air Setup Assistant[606]: ISAP: Done with Phase "Setup Assistant"
May 13 00:35:23 MacBook-Air Installer Progress[272]: caller = /System/Library/CoreServices/Setup Assistant.app/Contents/MacOS/Setup Assistant
May 13 00:35:23 MacBook-Air Setup Assistant[606]: client 0x60000191e3c0: phaseName = "Setup Assistant", hide progress UI called
May 13 00:35:23 MacBook-Air Setup Assistant[606]: ISAP: hide progress UI called
May 13 00:35:23 MacBook-Air Installer Progress[272]: Register process 606, phaseName Setup Assistant, uuid 413F9766-AD41-4C96-825E-698EE2F27F96
"413F9766-AD41-4C96-825E-698EE2F27F96" = {
"Phase Name" = "Setup Assistant";
"Process ID" = 606;
UUID = "413F9766-AD41-4C96-825E-698EE2F27F96";
May 13 00:35:23 MacBook-Air Installer Progress[272]: Saving completion handler for phase Setup Assistant
CompletionHandlerKey = "<__NSMallocBlock__: 0x600000b6e940>";
"Process ID" = 606;
May 13 00:35:23 MacBook-Air Installer Progress[272]: Ignoring the progress update because "Setup Assistant" isn't one of the phases (
May 13 00:35:23 MacBook-Air Installer Progress[272]: Done with phase = "Setup Assistant"
May 13 00:35:23 MacBook-Air Installer Progress[272]: Phase "Setup Assistant" is not a registered phase, ending progress
May 13 00:35:23 MacBook-Air Installer Progress[272]: IASClearInstallProgress: Clearing Registry
May 13 00:35:23 MacBook-Air Installer Progress[272]: The Progress UI has been hidden
May 13 00:35:24 MacBook-Air Installer Progress[272]: Calling animation completion handler
May 13 00:35:24 MacBook-Air Installer Progress[272]: Progress complete, notifying registered clients
May 13 00:35:24 MacBook-Air Installer Progress[272]: Calling completion handler for phase "Setup Assistant"
May 13 00:35:24 MacBook-Air Setup Assistant[606]: Calling completion handler for 0x60000191e3c0
May 13 00:35:24 MacBook-Air Installer Progress[272]: Order Out CG Shield Window
May 13 00:35:27 MacBook-Air Setup Assistant[606]: client 0x60000191e3c0: phaseName = "Setup Assistant" is being released
May 13 00:35:27 MacBook-Air Setup Assistant[606]: Releasing Connection
May 13 00:35:27 MacBook-Air Installer Progress[272]: Saving completion handler for phase Setup Assistant
May 13 00:35:27 MacBook-Air Installer Progress[272]: Connected processes {
CompletionHandlerKey = "<__NSMallocBlock__: 0x600000b750e0>";
"Process ID" = 606;
May 13 00:35:27 MacBook-Air Installer Progress[272]: Unregister process 606, phaseName Setup Assistant, uuid 413F9766-AD41-4C96-825E-698EE2F27F96
May 13 00:35:27 MacBook-Air Installer Progress[272]: Start quit timer, will attempt to quit in 1 second(s) at 12:35:28 AM
May 13 00:35:28 MacBook-Air Installer Progress[272]: Quitting because there are no phases. There are no connected processes. The UI is not showing.
May 13 00:35:28 MacBook-Air Installer Progress[272]: Quitting Progress App
May 13 00:35:28 MacBook-Air Installer Progress[272]: Showing the cursor in Progress UI
May 13 00:35:28 MacBook-Air Installer Progress[272]: GUI session is logged in
May 13 00:35:28 MacBook-Air Installer Progress[272]: Order Out CG Shield Window
May 13 00:35:28 MacBook-Air Installer Progress[272]: Setting window alpha values to 0.0
May 13 00:35:28 MacBook-Air Setup Assistant[606]: The connection was interrupted, calling interruption handlers
May 13 00:35:28 MacBook-Air loginwindow[312]: The connection was interrupted, calling interruption handlers
May 13 00:36:19 MacBook-Air loginwindow[312]: There is still an active connection
May 13 00:36:53 --- last message repeated 1 time ---
May 13 00:45:14 MacBook-Air syslogd[275]: ASL Sender Statistics
May 13 01:00:39 MacBook-Air syslogd[275]: ASL Sender Statistics
May 13 01:17:12 MacBook-Air syslogd[275]: ASL Sender Statistics
May 13 01:27:27 MacBook-Air syslogd[275]: ASL Sender Statistics
May 13 01:37:28 MacBook-Air syslogd[275]: ASL Sender Statistics
May 13 01:47:28 MacBook-Air syslogd[275]: ASL Sender Statistics
