Disconnecting from matches affects your (DNF) - FUT 21
Disconnecting From Matches Affects Your Did Not Finish Modified Fut21
Disconnecting From Matches Affects Your Did Not Finish Modified Fut21 (67.26 KiB) Viewed 811 times
It seems that you disconnected from your last online match. Disconnecting from matches affects your "Did Not Finish (DNF)" Modifier whih reduces the coins you receive from future matches.
