DEV ERROR 6034 [ww_m_hardhat.ff] (Call of Duty)
Dev Error 6034 Hardhat Ff Call Of Duty
Dev Error 6034 Hardhat Ff Call Of Duty (23.62 KiB) Viewed 1726 times
arohon
Re: DEV ERROR 6034 [ww_m_hardhat.ff] (Call of Duty)
Post by arohon »
When i faced this problem helped this:
Clear the Cache of the Xbox
Modern Warfare may show the dev error 6034 on Xbox One if the cache of the Xbox is corrupt. In this case, clearing the cache of the Xbox may solve the problem.
Press the power button of your Xbox and let it completely shut down (till all lights are off).
Now unplug the power cable from the back of the Xbox and electrical socket. Then wait for one minute.
Unplug the Power Cable from the Back of the Xbox
Now plug back the power cable to the back of the Xbox and socket.
Then wait for one more minute or if you are using Xbox One (not S or X series), then wait till the white light on the power brick turns orange.
Wait Till the Xbox One Light is Orange
Now power on the Xbox and check if it is clear of the error 6034.
Clear the Reserved Space of the Game
Reserved space is used to hold patches and updates of the game but if the game is having issues in accessing the reserved space, then it may show the dev error 6034. In this context, clearing the reserved space of the Modern Warfare game may solve the problem
Hover over the Modern Warfare in Xbox and press the Options button to open the game menu.
Now select Manage Game and Add-ons.
Open Manage Game & Add-ons of the Modern Warfare on Xbox
Then navigate to the Saved Data tab and in the left pane, open Reserved Space.
Now select Clear Reserved Space and confirm to clear the reserved space.
Clear Reserved Space of the Modern Warfare
Then reboot your console and upon reboot, check if it is clear of the dev error 6034.
If that did not do the work, check if deleting the files from the game vault (if the game files are saved on the internal storage and game vault) in the Saved Data tab (steps 1 to 3) of Modern Warfare resolves the issue at hand.
