DXGI_ERROR_INVALID_CALL (DirectX Error)
Directx Function Failed Dxgi Error Invalid Call
Directx Function Failed Dxgi Error Invalid Call (43.79 KiB) Viewed 2356 times
DirectX function m_dxgiFactory CreateSwapChain failed with DXGI_ERROR_INVALID_CALL: The application has made an erroneous API call that it had enough information to avoid. This error is intended to denote that the application should be altered to avoid this error. Use of the debug version of the DXGI.DLL will provide run-time debug output with further information.
