The Uniswap invariant x*y=k was not satisfied by the swap.
The Uniswap Invariant X Y K Was Not Satisfied By The Swap
The Uniswap Invariant X Y K Was Not Satisfied By The Swap (33.78 KiB) Viewed 3297 times
The Uniswap invariant x*y=k was not satisfied by the swap. This usually means one of the tokens you are swapping incorporates custom behavior on transfer.
