Your PHP version, 7.2.14, is only receiving security fixes from the PHP project at this time. (Joomla)
Joomla Your Php Version Receiving Security Fixes
Joomla Your Php Version Receiving Security Fixes (33.84 KiB) Viewed 1656 times
Warning
Your PHP version, 7.2.14, is only receiving security fixes from the PHP project at this time. This means your PHP version will soon no longer be supported. We recommend planning to upgrade to a newer PHP version before it reaches end of support on 2020-11-30. Joomla will be faster and more secure if you upgrade to a newer PHP version. Please contact your host for upgrade instructions.
