Fix: Unexpected token < in JSON at position 4 (Azure DevOps)
You must re-authenticate to Azure DevOps - sign out and back in from the web interface (upper right corner near your name). Your SSO password likely has changed or your Active Directory account is locked out.
Unexpected Token In Json At Position 4
Unexpected Token In Json At Position 4 (65.49 KiB) Viewed 3564 times
