GLFW error 65542 WGL (Minecraft)
Glfw Error 65542 Wgl Minecraft
Glfw Error 65542 Wgl Minecraft (26.97 KiB) Viewed 3767 times
GLFW error 65542: WGL: The driver does not appear to support OpenGL.
hardeep0607
Re: GLFW error 65542 WGL (Minecraft)
Post by hardeep0607 »
GLFW error 65542: WGL: The driver does not appear to support OpenGL is a common error and you can fix it by adding the missing opengl32.dll manually into the Java Directory (JRE), but if this won’t work then reinstalling and updating the GPU drivers to support OpenGL may do the trick.
