System mode client started - Console (730) - mode: 0xb, filter:
Aug 14 12:50:08 KOS com.apple.geod[712]: objc[712]: Class GEOETAProvider is implemented in both /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices and /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod. One of the two will be used. Which one is undefined.
Aug 14 12:50:44 KOS com.apple.xpc.launchd[1] (com.apple.mdworker.shared.03000000-0100-0000-0000-000000000000[683]): Service exited due to SIGKILL | sent by mds[129]
Aug 14 12:50:45 KOS syncdefaultsd[715]: objc[715]: Class SYDClient is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Aug 14 12:50:45 KOS syncdefaultsd[715]: objc[715]: Class SYDJournal is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Aug 14 12:50:47 KOS com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.recentsd.720): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd, error = 2: No such file or directory
Aug 14 12:50:50 KOS accountsd[379]: accountsd(379,0x70000e9ff000) malloc: malloc_memory_event_handler: approaching memory limit. Starting stack-logging.
Aug 14 12:50:50 KOS accountsd[379]: accountsd(379,0x70000e9ff000) malloc: recording malloc (and VM allocation) stacks using lite mode
Aug 14 12:50:51 KOS accountsd[379]: accountsd(379,0x70000de3a000) malloc: malloc_memory_event_handler: stopping stack-logging
Aug 14 12:50:51 KOS accountsd[379]: accountsd(379,0x70000de3a000) malloc: turning off recording malloc and VM allocation stacks using lite mode
Aug 14 12:50:51 KOS accountsd[379]: accountsd(379,0x70000d899000) malloc: MallocStackLogging: stack id is invalid. Turning off stack logging
Aug 14 12:50:51 KOS accountsd[379]: accountsd(379,0x70000d899000) malloc: malloc stack logging not enabled.
Aug 14 12:51:28 KOS xpcproxy[728]: libcoreservices: _dirhelper_userdir: 557: bootstrap_look_up returned (ipc/send) invalid destination port
Aug 14 12:51:30 KOS diagnosticd[731]: Posting empty stream filter
Aug 14 12:51:30 KOS diagnosticd[731]: no EOS device present
Aug 14 12:51:30 KOS diagnosticd[731]: allowing Console (730) access to stream due to admin status
Aug 14 12:51:30 KOS diagnosticd[731]: Posting stream filter: "{
global = 47245099008;
Aug 14 12:51:30 KOS diagnosticd[731]: System mode client started - Console (730) - mode: 0xb, filter: "<empty>"
