Google AdSense Contact - Site Pending Review Response
Make sure your site is reachable
Did you provide the correct URL? If you made a mistake, please remove the site from your sites list and add a new site with the correct URL.
Is your site up and running? Make sure your site is published and live on the web.
Can AdSense access your site without a password? If your site's login-protected, consider temporarily removing the login so that we can reach your site. Note that after your account has been successfully activated, you can create a crawler login to display Google ads on your login-protected pages
Can the AdSense crawler access your site? Review our Fix on AdSense crawler issues.
Make sure you have verified the ownership of your site
Make sure that you've placed the AdSense code on the site and pages that you want to monetize. Check our AdSense code implementation guide.
If you'd prefer not to paste the code on your site, you can verify your site ownership in Search Console instead. If we detect that you've verified your site in Search Console, we'll continue checking if your site is ready to show ads.
If you have an ads.txt file, make sure that this one is updated with your publisher ID.
Make sure your site has unique content and a good user experience
Provide enough unique content that gives users a reason to visit, and return to your site.
Also, it’s important to ensure that your site does not have any duplicate content.
Your site should have a good navigation menu and your site’s content should be organized in a manner that is easy for users to easily find it.
We recommend reviewing our tips on how to establish a high-quality site and deliver a good user experience.
Make sure your site is complain with AdSense program policies
Make sure that you adhere to the AdSense program policies.
Review that the content on your site is compliant with our Publisher content policies.
