Could not update smart object files because the file is locked (Adobe)
Could Not Update Smart Object Files Because File Is Locked Adobe Photoshop
Could Not Update Smart Object Files Because File Is Locked Adobe Photoshop (94.49 KiB) Viewed 3638 times
Adobe Photoshop
Could not update smart object files because the file is locked, you do not have necessary access permissions, or another program is using the file. Use the Get Info command in the Finder to ensure the file is unlocked and you have permission to access the file.
