You must use Migration Assistant to transfer data from this backup.
This is likely because you are trying to do a restore from Intel <-> ARM and likely have incompatible hardware/software requirements and Migration assistant will only work.
Reinstall macOS if necessary and then use Migration Assistant to transfer data from your backup.
You Must Use Migration Assistant To Transfer Data From This Backup Time Machine Restore Macos
You Must Use Migration Assistant To Transfer Data From This Backup Time Machine Restore Macos (127.64 KiB) Viewed 25181 times
