Not restricted as per special provision a1
This commodity may be transported on passenger aircraft, only with the prior approval of the appropriate authority of the State of Origin under the written conditions established by that authority. The conditions must include the quantity limitations and packing requirements and these must comply with S-3;1.2.2 of the Supplement. A copy of the document of approval, showing the quantity limitations and packing requirements, must accompany the consignment. The commodity may be carried on cargo aircraft in accordance with columns 11 and 12 of Table 3-1. When States, other than the State of Origin, have notified ICAO that they require prior approval of shipments made under this special provision, approval must also be obtained from these States, as appropriate.
Not restricted as per special provision a2
This commodity may be transported on passenger aircraft and on cargo aircraft, only with the prior approval of the appropriate authority of the State of Origin under the written conditions established by the authority.
Where States, other than the State of Origin, have notified ICAO that they require prior approval of shipments made under this special provision, approval must also be obtained from the States of transit, overflight and destination and of the State of the Operator, as appropriate.
In each case the conditions must include the quantity limitations and packing requirements and these must comply with S-3;1.2.3 of the Supplement. A copy of the document(s) of approval, showing the quantity limitations and the packing and labelling requirements, must accompany the consignment.
Not restricted as per special provision a3
If the chemical or physical properties of a substance covered by this description are such that, when tested, it does not meet the established defining criteria for the class or division listed in column 3, or any other class or division, it is not subject to these Instructions.
Not restricted as per special provision a4
Liquids having a vapour inhalation toxicity of Packing Group I are forbidden on both passenger and cargo aircraft.
Liquids having a mist inhalation toxicity of Packing Group I are forbidden on a passenger aircraft. They may be carried on cargo aircraft providing they are packed in accordance with the packing instructions for the Packing Group I substance and the maximum net quantity per package does not exceed 5 L.
Not restricted as per special provision a5
Solids having an inhalation toxicity of Packing Group I are forbidden on passenger aircraft. They may be carried on cargo aircraft providing they are packed in accordance with the packing instructions for the Packing Group I substance and the maximum net quantity per package does not exceed 15 kg.
Not restricted as per special provision a6
When offered for carriage as pesticides, these substances must be carried under the relevant pesticide entry and in accordance with the relevant pesticide provision
Not restricted as per special provision a8
When transported in non-friable tablet form, these goods are assigned to Packing Group III.
Not restricted as per special provision a9
Alcoholic beverages containing not more than 70 per cent alcohol by volume, when packed in receptacles of 5 litres or less, are not subject to these Instructions when carried as cargo.
Not restricted as per special provision a10
This substance is not subject to these Instructions when it contains less than 30 per cent or not less than 90 per cent silicon.
Not restricted as per special provision a11
These substances are not subject to these Instructions when in concentrations of not more than 50 mg/kg.
Not restricted as per special provision a12
Antimony sulphides and oxides which contain not more than 0.5 per cent of arsenic calculated on the total weight mass are not subject to these Instructions.
Not restricted as per special provision a13
Ferricyanides and ferrocyanides are not subject to these Instructions.
Not restricted as per special provision a15
These substances are not subject to these Instructions when they contain not more than 50 per cent magnesium.
Not restricted as per special provision a17
These substances must not be classified and transported unless authorized by the appropriate authority of the State of Origin on the basis of results from Series 2 tests and a Series 6(c) test on packages as prepared for transport.
Not restricted as per special provision a18
Mercurous chloride and cinnabar are not subject to these Instructions.
Not restricted as per special provision a20
During the course of transport this substance must be protected from direct sunlight and all sources of heat and be placed in an adequately ventilated area. A statement to this effect must be included in the Dangerous Goods Transport Document.
Not restricted as per special provision a21
This entry only applies to vehicles and equipment which are powered by wet batteries, sodium batteries or lithium batteries and which are transported with these batteries installed. Examples of such vehicles and equipment are electrically-powered cars, lawn mowers, wheelchairs and other mobility aids. Vehicles that also contain an internal combustion engine must be consigned under the entry Vehicle (flammable gas powered) or Vehicle (flammable liquid powered), as appropriate. Hybrid electric vehicles powered by both an internal combustion engine and wet batteries, sodium batteries or lithium batteries, transported with the battery(ies) installed, must be consigned under the entries UN 3166 Vehicle, flammable gas powered or UN 3166 Vehicle, flammable liquid powered, as appropriate.
Not restricted as per special provision a22
The classification of this substance will vary with particle size and packaging, but borderlines have not been experimentally determined. The appropriate classification must be made using the procedure for the classification of explosives.
Not restricted as per special provision a23
In the case of non-fissile or fissile excepted uranium hexafluoride, the material must be classified under UN 2978.
Not restricted as per special provision a24
The total quantity of explosive substance contained in the shaped charges and the detonating cord must not exceed 10 kg per assembled perforating gun.
Not restricted as per special provision a25
This entry must not be used for Pentachlorophenol (UN 3155).
Not restricted as per special provision a26
Refrigerating machines include air conditioning units and machines or other appliances which have been designed for the specific purpose of keeping food or other items at low temperature in an internal compartment. Refrigerating machines and refrigerating machine components are considered not subject to these Instructions if containing less than 12 kg of a gas in Division 2.2 or if containing less than 12 L ammonia solution (UN 2672).
Not restricted as per special provision a27
This includes any substance which is not covered by any of the other classes but which has narcotic, noxious or other properties such that, in the event of spillage or leakage on an aircraft, extreme annoyance or discomfort could be caused to crew members so as to prevent the correct performance of assigned duties.
Not restricted as per special provision a28
The dihydrated sodium salt of dichloroisocyanuric acid is not subject to these Instructions.
Not restricted as per special provision a29
p-Bromobenzyl cyanide is not subject to these Instructions.Not restricted as per special provision a30
Not restricted as per special provision a31
Products which have undergone sufficient heat treatment so they present no hazard during transport are not subject to these Instructions.
Not restricted as per special provision a32
Air bags inflators, air bag modules or seat-belts pretensioners installed in conveyances or in completed conveyance components such as steering columns, door panels, seats, etc., which are not capable of inadvertent activation are not subject to these Instructions.
Not restricted as per special provision a33
Ammonium nitrites and mixtures of an inorganic nitrite with an ammonium salt are prohibited.
Not restricted as per special provision a34
The transport of chemically unstable mixtures is prohibited.
Not restricted as per special provision a35
This substance is not subject to these Instructions when:
— mechanically produced, particle size more than 53 microns; or
— chemically produced, particle size more than 840 microns.
Not restricted as per special provision a36
The provisions of Special Provision A2 apply to this entry for Packing Group I only and the provisions of Special
Provision A1 apply to this entry for Packing Group II only, as applicable.
Not restricted as per special provision a37
This entry is not intended to include Ammonium permanganate, the transport of which is prohibited under any circumstances.
Not restricted as per special provision a38
Polymeric beads and moulding compounds may be made from polystyrene, poly(methyl methacrylate) or other polymeric material.
Not restricted as per special provision a39
This substance possesses some dangerous explosive properties when transported in large volumes.
Not restricted as per special provision a40
This substance may be transported under provisions of Division 4.1 only if it is so packed that the percentage of diluent will not fall below that stated at any time during transport.
Not restricted as per special provision a41
Permeation devices that contain dangerous goods and that are used for calibrating air quality monitoring devices are not subject to these Instructions provided the following requirements are met:
a) Each device must be constructed of a material compatible with the dangerous goods it contains;
b) The total contents of dangerous goods in each device is limited to 2 millilitres and the device must not be
liquid full at 55ΕC;
c) Each permeation device must be placed in a sealed, high impact-resistant, tubular inner packaging of plastic or equivalent material. Sufficient absorbent material must be contained in the inner packaging to completely absorb the contents of the device. The closure of the inner packaging must be securely held in place with wire, tape or other positive means;
d) Each inner packaging must be contained in a secondary packaging constructed of metal, or plastic having a minimum thickness of 1.5 mm. The secondary packaging must be hermetically sealed;
e) The secondary packaging must be securely packed in strong outer packaging. The completed package must be capable of withstanding, without breakage or leakage of any inner packaging and without significant reduction in effectiveness:
Not restricted as per special provision a42
Ferrocerium (lighter flints), stabilized against corrosion, with a minimum iron content of 10 per cent are not subject to these Instructions.
Not restricted as per special provision a43
Toxins from plant, animal or bacterial sources which contain infectious substances, or toxins that are contained in infectious substances, must be classified as Division 6.2.
Not restricted as per special provision a44
Chemical kits or first aid kits include boxes, cases, etc., containing small amounts of one or more compatible items of dangerous goods which are used, for example, for medical, analytical or testing or repair purposes.
The only dangerous goods which are permitted in the kits are substances which may be transported as:
a) excepted quantities, under 1;2.4.2.2 provided the inner packagings and quantities are as prescribed in 1;2.4.3 a) and 1;2.4.4 a); or
b) limited quantities under 3;4.1.2.
Not restricted as per special provision a45
Lithium cCells and batteries offered for transport are not subject to other provisions of these Instructions if they meet the following:
a) For a lithium metal or lithium alloy cell, the lithium content is not more than 1 g, and for a lithium ion cell, the lithium-equivalent content is not more than 1.5 g Watt-hour rating is not more than 20 Wh;
b) For a lithium metal or lithium alloy battery, the aggregate lithium content is not more than 2 g, and for a lithium ion battery, the aggregate lithium-equivalent content is not more than 8 g Watt-hour rating is not more than 100 Wh. Lithium ion batteries subject to this provision must be marked with the Watt-hour rating on the outside case;
c) Each cell or battery is of the type proved to meet the requirements of each test in the UN Manual of Tests and Criteria, Part III, subsection 38.3;
Not restricted as per special provision a46
Mixtures of solids which are not subject to these Instructions and flammable liquids may be transported under this entry without first applying the classification criteria of Division 4.1, providing there is no free liquid visible at the time the substance is packaged and the packaging must pass a leakproofness test at the Packing Group II level. Small inner packagings consisting of sealed packets or articles containing less than 10 mL of a Packing Group II or III flammable liquid absorbed into a solid material are not subject to these Instructions provided there is no free liquid in the packet or articles.
Not restricted as per special provision a47
Genetically modified micro-organisms and genetically modified organisms, which meet the definition of an infectious substance and the criteria for inclusion in Division 6.2 in accordance with 2;6, must be transported as UN 2814, UN 2900 or UN 3373, as appropriate.
Not restricted as per special provision a49
Other inert material or inert material mixture may be used at the discretion of the appropriate authority of the State of Origin, provided this inert material has identical phlegmatizing properties.
Not restricted as per special provision a50
Mixtures of solids which are not subject to these Instructions and toxic liquids may be transported under this entry without first applying the classification criteria of Division 6.1, providing there is no free liquid visible at the time the substance is packaged and the packaging must pass a leakproofness test at the Packing Group II level. This entry must not be used for solids containing a Packing Group I liquid.
Not restricted as per special provision a51
Irrespective of the limit specified in column 10 of Table 3-1, aircraft batteries up to a limit of 100 kg gross mass per package may be transported. Transport in accordance with this special provision must be noted on the dangerous goods transport document.
Not restricted as per special provision a52
Mixtures not meeting the criteria for flammable gases (Division 2.1) must be transported under UN 3163.
Not restricted as per special provision a53
This substance is not subject to these Instructions when coated.
Not restricted as per special provision a54
This substance is not subject to these Instructions when in any other form.
Not restricted as per special provision a55
Solvent extracted soya bean meal containing not more than 1.5 per cent oil and not more than 11 per cent moisture, which is substantially free of flammable solvent, is not subject to these Instructions.
Not restricted as per special provision a56
This entry applies to articles which contain Class 1 explosive substances and which may also contain dangerous goods of other classes. These articles are used as lifesaving vehicle air bag inflators or air bag modules or seat belt pretensioners.
The quantities given in columns 10 and 12 of Table 3-1 refer to the net mass of the finished article.
Not restricted as per special provision a57
Packagings must be so constructed that explosion is not possible by reason of increased internal pressure.
Not restricted as per special provision a58
An aqueous solution containing not more than 24 per cent alcohol by volume is not subject to these Instructions.
Not restricted as per special provision a59
A tire assembly unserviceable or damaged is not subject to these Instructions if the tire is completely deflated. A tire assembly with a serviceable tire is not subject to these Instructions provided the tire is not inflated to a gauge pressure exceeding the maximum rated pressure for that tire. However, such tires (including valve assemblies) must be protected from damage during transport, which may require the use of a protective cover.
Not restricted as per special provision a60
This entry only applies to the technically pure substance or to formulations derived from it having an SADT higher than 75ΕC and therefore does not apply to formulations which are self-reactive substances. (For self-reactive substances, see 2;4.2.3. Table 2-6). Homogeneous mixtures containing not more than 35 per cent by mass of azocarbonamide and at least 65 per cent of inert substance are not subject to these Instructions unless criteria of other classes or divisions are met.
Not restricted as per special provision a61
Asbestos which is immersed or fixed in a natural or artificial binder (such as cement, plastics, asphalt, resins or mineral ore) in such a way that no escape of hazardous quantities of respirable asbestos fibres can occur during transport is not subject to these Instructions. Manufactured articles, containing asbestos and not meeting this requirement, are nevertheless not subject to these Instructions, when packed so that no escape of hazardous quantities of respirable asbestos fibres can occur during transport.
Not restricted as per special provision a62
This designation must be used only when no other appropriate designation exists in the list and then only with the approval of the appropriate authority of the State of Origin.
Not restricted as per special provision a64
This entry may only be used for substances that do not exhibit explosive properties of Class 1 when
tested in accordance with test series 1 and 2 of Class 1 (see UN Manual of Tests and Criteria, Part I).
Not restricted as per special provision a65
Aqueous solutions of Division 5.1 inorganic solid nitrate substances are considered as not meeting the criteria of Division 5.1 if the concentration of the substances in solution at the minimum temperature encountered in transport is not greater than 80 per cent of the saturation limit.
Not restricted as per special provision a66
Polyester resin kits consist of two components: a base material (Class 3, Packing Group II or III) and an activator (Division 5.2). The organic peroxide must be type D, E or F, not requiring temperature control. Only organic peroxides that are authorized for transport on passenger aircraft are permitted in the kits. Those requiring temperature control are forbidden. Packing Group II or III is assigned according to the criteria for Class 3, applied to the base material. The quantity limit [and the excepted quantity code] shown in [1;2.4.3] apply to the base material.
Not restricted as per special provision a67
Non-spillable batteries meeting the requirements of Packing Instruction 806 are not subject to these Instructions if, at a temperature of 55°C, the electrolyte will not flow from a ruptured or cracked case. The battery must not contain any free or unabsorbed liquid.
Not restricted as per special provision a68
This substance must not be transported under the provisions of Division 4.1 unless specifically authorized by the appropriate national authority. (See UN 0143.)
Not restricted as per special provision a69
Articles, each containing not more than 100 mg of mercury, gallium or inert gas and packaged so that the quantity of mercury, gallium or inert gas per package does not exceed 1 g, are not subject to these Instructions when carried as cargo.
Not restricted as per special provision a70
Internal combustion engines being shipped either separately or incorporated into a machine or other apparatus, the fuel tank of which has never contained any fuel, and the fuel system of which is completely empty of fuel, or that are powered by a fuel that does not meet the classification criteria for any class or division, and without batteries or other dangerous goods, are not subject to these Instructions.
Not restricted as per special provision a71
This substance is not subject to these Instructions when it contains not more than 0.1 per cent calcium carbide.
Not restricted as per special provision a72
A substance specifically listed by name in Table 3-1 must not be transported under this entry. Materials transported under this entry may contain 20 per cent or less nitrocellulose provided the nitrocellulose contains not more than 12.6 per cent nitrogen.
Not restricted as per special provision a73
The membrane filters, including paper separators, coating, or backing materials, etc., that are present in transport, must not be liable to propagate a detonation as tested by one of the tests described in the UN Manual of Tests and Criteria, Part I, Test Series 1(a).
In addition, the appropriate authority may determine, on the basis of the results of suitable burning rate tests taking account of the standard tests in the UN Manual of Tests and Criteria, Part III, subsection 33.2.1, that nitrocellulose membrane filters in the form in which they are to be transported are not subject to the provisions of these Instructions applicable to flammable solids in Division 4.1.
Not restricted as per special provision a74
Phthalic anhydride in the solid state and tetrahydrophthalic anhydrides, with not more than 0.05 per cent maleic anhydride, are not subject to these Instructions. Phthalic anhydride molten at a temperature above its flash point, with not more than 0.05 per cent maleic anhydride, must be classified under UN 3256.
Not restricted as per special provision a75
Articles such as sterilization devices, when containing less than 30 mL per inner packaging with not more than 150 mL per outer packaging, may be transported on passenger and cargo aircraft in accordance with the provisions in 1;2.4, irrespective of 1;2.4.2.2 and the indication of “forbidden” in columns 9 to 12 of the Dangerous Goods List (Table 3-1), provided such packagings were first subjected to comparative fire testing. Comparative fire testing must show no difference in burning rate between a package as prepared for transport (including the substance to be transported) and an identical package filled with water.
Not restricted as per special provision a76
In the case of fissile uranium hexafluoride, the material must be classified under UN 2977.
Not restricted as per special provision a77
Mixtures of solids which are not subject to these Instructions and corrosive liquids may be transported under this entry without first applying the classification criteria of Class 8, providing there is no free liquid visible at the time the substance is packaged and the packaging must pass a leakproofness test at the packing group II level.
Not restricted as per special provision a78
Radioactive material with a subsidiary risk must:
a) be labelled with subsidiary risk labels corresponding to each subsidiary risk exhibited by the material in accordance with the relevant provisions of 5;3.2; corresponding placards must be affixed to transport units in accordance with the relevant provisions of 5;3.6;
b) be allocated to Packing Groups I, II or III, as and if appropriate, by application of the grouping criteria provided in Part 2 corresponding to the nature of the predominant subsidiary risk.
The description required in 5;4.1.5.7.1 b) must include a description of these subsidiary risks (e.g. “Subsidiary risk: 3,6.1”), the name of the constituents which most predominantly contribute to this (these) subsidiary risk(s) and, where applicable, the packing group.
Not restricted as per special provision a79
This entry may only be used for uniform mixtures containing ammonium nitrate as the main ingredient within the following composition limits:
a) not less than 90 per cent ammonium nitrate with not more than 0.2 per cent total combustible/organic material calculated as carbon and with added matter, if any, which is inorganic and inert towards ammonium nitrate; or
b) less than 90 per cent but more than 70 per cent ammonium nitrate with other inorganic materials or more than 80 per cent but less than 90 per cent ammonium nitrate mixed with calcium carbonate and/or dolomite and/or mineral calcium sulphate and not more than 0.4 per cent total combustible/organic material calculated as carbon; or
c) nitrogen type ammonium nitrate based fertilizers containing mixtures of ammonium nitrate and ammonium sulphate with more than 45 per cent but less than 70 per cent ammonium nitrate and not more than 0.4 per cent total combustible/organic material calculated as carbon such that the sum of the percentage composition of ammonium nitrate and ammonium sulphate exceeds 70 per cent.
Not restricted as per special provision a80
The technical name of the flammable liquid component only of this solution or mixture must be shown in parenthesis immediately following the proper shipping name.
Not restricted as per special provision a81
The quantity limit shown in column 10 does not apply to body fluids known to contain or suspected of containing infectious substances provided they are not in risk group 4, when in primary receptacles not exceeding 1000 mL, and in outer packagings not exceeding 4 L. The quantity limits shown in columns 10 and 12 do not apply to body parts, organs or whole bodies known to contain or suspected of containing infectious substances.
Not restricted as per special provision a82
Barium sulphate is not subject to these Instructions.
Not restricted as per special provision a83
The commercial grade of calcium nitrate fertilizer, when consisting mainly of a double salt (calcium nitrate and ammonium nitrate) containing not more than 10 per cent ammonium nitrate and at least 12 per cent water of crystallization, is not subject to these Instructions.
Not restricted as per special provision a84
The group of alkali metals includes lithium, sodium, potassium, rubidium and caesium.
Not restricted as per special provision a85
The group of alkaline earth metals includes magnesium, calcium, strontium and barium.
Not restricted as per special provision a86
The formulation must be prepared so that it remains homogeneous and does not separate during transport. Formulations with low nitrocellulose contents are not subject to these Instructions provided that 1) they do not exhibit dangerous properties when tested for their liability to detonate, deflagrate or explode when heated under defined confinement by tests of test series 1(a), 2(b) and 2(c) respectively in the UN Manual of Tests and Criteria and 2) they are not flammable solids when tested in accordance with test N1 in the UN Manual of Tests and Criteria, Part III, subsection 3.3.2.1.4 (chips, if necessary, crushed and sieved to a particle size of less than 1.25 mm).
Not restricted as per special provision a87
Articles which are not fully enclosed by packaging, crates or other means that prevent ready identification are not subject to the marking requirements of 5;2 or the labelling requirements of 5;3.
Not restricted as per special provision a88
Prototype lithium batteries and cells to be tested that are packed with not more than 24 cells or 12 batteries per packaging that have not been tested to the requirements in subsection 38.3 of the UN Manual of Tests and Criteria may be transported aboard cargo aircraft if approved by the appropriate authority of the State of Origin and the following requirements are met:
a) the cells and batteries must be transported in an outer packaging that is a metal, plastic or plywood drum or a metal, plastic or wooden box and that meets the criteria for Packing Group I packagings; and
b) each cell and battery must be individually packed in an inner packaging inside an outer packaging and surrounded by cushioning material that is non-combustible, and non-conductive. Cells and batteries must be protected against short circuiting.
Not restricted as per special provision a89
In determining the ammonium nitrate content, all nitrate ions for which a molecular equivalent of ammonium ions is present in the mixture shall be calculated as ammonium nitrate.
Not restricted as per special provision a90
This entry may only be used for uniform ammonium nitrate based fertilizer mixtures of the nitrogen, phosphate or potash type, containing not more than 70 per cent ammonium nitrate and not more than 0.4 per cent total combustible/organic material calculated as carbon or with not more than 45 per cent ammonium nitrate and unrestricted combustible material. Fertilizers within these composition limits are not subject to these Instructions if shown by a Trough Test (see UN Manual of Tests and Criteria, Part III, subsection 38.2) not to be liable to self-sustaining decomposition.
Not restricted as per special provision a91
A nitrocellulose solution containing not more than 20 per cent nitrocellulose may be transported under the requirements for “Paint” or “Printing ink” as applicable; see UN 1210, 1263 and, 3066, 3469 and 3470.
Not restricted as per special provision a92
Lead compounds which, when mixed in a ratio of 1:1000 with 0.07 M hydrochloric acid and stirred for 1 hour at a temperature of 23°C ±2°C, exhibit a solubility of 5 per cent or less are considered insoluble (see ISO 3711:1990 “Lead chromate pigments and lead chromate-molybdate pigments — Specifications and methods of test”) are considered insoluble and are not subject to these Instructions unless they meet the criteria for inclusion in another hazard class or division.
Not restricted as per special provision a93
A heat-producing article is not subject to these Instructions when the heat-producing component or the energy source is removed to prevent unintentional functioning during transport.
Not restricted as per special provision a94
Batteries or cells containing sodium must not contain dangerous goods other than sodium, sulphur and/or polysulphides. Batteries or cells must not be offered for transport at a temperature such that liquid elemental sodium is present in the battery or cell unless approved and under the conditions established by the appropriate national authority.
Cells must consist of hermetically sealed metal casings which fully enclose the dangerous goods and which are so constructed and closed as to prevent the release of the dangerous goods under normal conditions of transport.
Batteries must consist of cells secured within and fully enclosed by a metal casing so constructed and closed as to prevent the release of the dangerous goods under normal conditions of transport.
Not restricted as per special provision a95
This entry is not to be used for Polychlorinated biphenyls (UN 2315).
Not restricted as per special provision a97
These entries may be used for substances which are hazardous to the environment but do not meet the classification criteria of any other class or other substance within Class 9. This must be based on the criteria in the Regulations of other modes of transport or criteria recognized by the appropriate authority of the State of origin, transit or destination. This designation may also be used for wastes not otherwise subject to these Instructions but which are covered under the Basel Convention on the Control of Transboundary Movements of Hazardous Wastes and their Disposal.
Not restricted as per special provision a98
Aerosols, gas cartridges and receptacles, small, containing gas with a capacity not exceeding 50 ml, containing no constituents subject to these Instructions other than a Division 2.2 gas, are not subject to these Instructions unless their release could cause extreme annoyance or discomfort to crew members so as to prevent the correct performance of assigned duties.
Not restricted as per special provision a99
Irrespective of the limit specified in column 12 of Table 3-1, a lithium battery or battery assembly that has successfully passed the tests specified in the UN Manual of Tests and Criteria, Part III, subsection 38.3, and that meets the requirements of Packing Instruction 903 as prepared for transport may have a mass exceeding 35 kg G, if approved by the appropriate authority of the State of Origin. A copy of the document of approval must accompany the consignment.
Not restricted as per special provision a100
Gasoline, motor spirit and petrol for use in spark-ignition engines (e.g. in automobiles, stationary engines and other engines) must be assigned to this entry regardless of variations in volatility.
Not restricted as per special provision a101
When phlegmatized with water and inorganic inert material, the content of urea nitrate may not exceed 75 per cent by mass and the mixture must not be capable of being detonated by the series 1 type (a) test in the UN Manual of Tests and Criteria, Part I.
Not restricted as per special provision a102
This listing includes aluminium dross, aluminium skimmings, spent cathodes, spent potliner and aluminium salt slags.
Not restricted as per special provision a103
Flammable liquefied gases must be contained within refrigerating machine components. These components must be designed and tested to at least three times the working pressure of the machinery. The refrigerating machines must be designed and constructed to contain the liquefied gas and preclude the risk of bursting or cracking of the pressure-retaining components during normal conditions of transport. Refrigerating machines and refrigerating machine components are considered not subject to these Instructions if containing less than 100 g flammable, non-toxic, liquefied gas.
Not restricted as per special provision a104
A toxic subsidiary risk label, although not required by these Instructions, may be applied.
Not restricted as per special provision a105
Sulphur is not subject to these Instructions when it has been formed to a specific shape (e.g. prills, granules, pellets, pastilles or flakes).
Not restricted as per special provision a106
This entry may only be used for samples of chemicals taken for analysis in connection with the implementation of the Chemical Weapons Convention. They may be transported on a passenger or cargo aircraft providing prior approval has been granted by the appropriate authority of the State of Origin or the Director General of the Organization for the Prohibition of Chemical Weapons and providing the samples comply with the requirements shown against the entry for chemical samples in Table S-3-1 of the Supplement.
The substance is assumed to meet the criteria of Packing Group I for Division 6.1. Subsidiary risk labelling is not required.
A copy of the document of approval showing the quantity limitations and the packing requirements must accompany the consignment.
Not restricted as per special provision a107
This entry only applies to machinery or apparatus containing dangerous goods as a residue or as an integral element of the machinery or apparatus. It must not be used for machinery or apparatus for which a proper shipping name already exists in Table 3-1.
Not restricted as per special provision a108
The provisions of Special Provision A1 apply to this entry for Packing Group I only.
Not restricted as per special provision a109
This commodity may be transported on cargo aircraft, only with the prior approval of the appropriate authority of the State of Origin under the written conditions established by that authority. The conditions must include the quantity limitations and packing requirements and these must comply with S-3;1.2.4 of the Supplement. A copy of the document of approval, showing the quantity limitations and packing requirements, must accompany the consignment.
Where States, other than the State of Origin, have notified ICAO that they require prior approval of shipments made under this special provision, approval must also be obtained from these States, as appropriate.
Not restricted as per special provision a110
Formulations of these substances containing not less than 30 per cent non-volatile, non-flammable phlegmatizer are not subject to these Instructions.
Not restricted as per special provision a111
Oxygen generators, chemical, that have passed their expiration date, are unserviceable or that have been used are forbidden for transport.
Not restricted as per special provision a112
Consumer commodities may only include substances of Class 2 (non-toxic aerosols only), Class 3, Packing Group II or III, Division 6.1 (Packing Group III only) and UN 3175, provided such substances do not have a subsidiary risk. Dangerous goods that are forbidden for transport aboard passenger aircraft must not be transported as consumer commodities.
Not restricted as per special provision a113
The substance is assigned to this classification or Packing Group based on human experience rather than the strict application of classification criteria set out in the Instructions.
Not restricted as per special provision a114
Articles, containing gas, intended to function as shock absorbers, including impact energy absorbing devices, or pneumatic springs are not subject to these Instructions provided:
a) each article has a gas space capacity not exceeding 1.6 litres and a charge pressure not exceeding 280 bar where the product of the capacity (litres) and charge pressure (bars) does not exceed 80 (i.e. 0.5 litre gas space and 160 bar change pressure, 1 litre gas space and 80 bar charge pressure, 1.6 litre gas space and 50 bar charge pressure, 0.28 litre gas space and 280 bar charge pressure);
b) each article has a minimum burst pressure of 4 times the charge pressure at 20°C for products not exceeding 0.5 litre gas space capacity and 5 times charge pressure for products greater than 0.5 litre gas space capacity;
c) each article is manufactured from material which will not fragment upon rupture;
d) each article is manufactured in accordance with a quality assurance standard acceptable to the appropriate national authority; and
e) the design type has been subjected to a fire test demonstrating that pressure in the article is relieved by means of a fire-degradable seal or other pressure-relief device such that the article will not fragment and the article does not rocket.
Not restricted as per special provision a115
This entry applies to articles which are used as lifesaving vehicle air bag inflators, or air bag modules or seat belt pretensioners, and which contain dangerous goods of Class 1 or dangerous goods of other classes and when transported as component parts and when these articles as presented for transport have been tested in accordance with test series 6 (c) of Part I of the UN Manual of Tests and Criteria, with no explosion of the device, no fragmentation of the device casing or pressure vessel, no projection hazard and no thermal effect which would significantly hinder firefighting or other emergency response efforts in the immediate vicinity.
Not restricted as per special provision a116
An oxygen generator, chemical, when containing an explosive actuating device must only be transported under this entry when excluded from Class 1 in accordance with 2;1.1 b).
Not restricted as per special provision a117
Wastes transported under UN 3291 are wastes derived from the medical treatment of humans or animals or from bio-research, where there is a relatively low probability that infectious substances are present. Waste infectious substances which can be specified must be assigned to UN 2814 or UN 2900. Decontaminated wastes which previously contained infectious substances may be considered as not subject to these Instructions unless the criteria of another class or division are met.
Not restricted as per special provision a118
Items classified as explosive must be removed from vehicles and transported in accordance with the provisions of these Instructions unless authorized by the appropriate national authority under the written conditions established by that authority. In such circumstances, vehicles may be transported on cargo aircraft only.
Note.— This special provision does not apply where the explosives are a smoke candle installed as a permanent part of the vehicle or are part of an assembly classified as dangerous goods of other than Class 1, e.g. Air bag inflators, Air bag modules and Seat-belt pretensioners (UN 3268), Fire extinguishers (UN 1044). Additionally, this special provision does not apply in the case of Air bag modules and Air bag inflators and Seat- belt pretensioners (UN 0503) installed in the vehicle.
Not restricted as per special provision a119
Irrespective of the limit specified in column 12 of Table 3-1, a handling device meeting the requirements of Packing Instruction 917 as prepared for transport may have a gross mass not exceeding 1 000 kg.
Not restricted as per special provision a120
This entry includes but is not limited to automobiles, motorcycles, aircraft, boats, snowmobiles, jet skis, etc.
Not restricted as per special provision a122
Nitrocellulose membrane filters covered by this entry, each with a mass not exceeding 0.5 g, are not subject to these Instructions when contained individually in an article or a sealed packet.
Not restricted as per special provision a123
Special Provision A123 of the Technical Instructions specifies the measures which must be taken with regard to the protection against short circuit of electric storage batteries (included when fitted in equipment) which have the potential of a dangerous evolution of heat. While protection against short circuit is clearly essential, a number of incidents have occurred not because of short circuit but rather because of unintentional activation, particularly in the case of power tools, e.g. drills. It is suggested Special Provision A123 should reflect this.
Not restricted as per special provision a124
Mixtures containing not more than 23.5 per cent oxygen by volume may be transported under this entry when no other oxidizing gases are present. A Division 5.1 subsidiary risk label is not required for any concentrations within this limit.
Not restricted as per special provision a125
The following definitions apply to matches:
a) Fusee matches are matches the heads of which are prepared with a friction-sensitive igniter composition and a pyrotechnic composition which burns with little or no flame, but with intense heat;
b) Safety matches are combined with or attached to the box, book or card that can be ignited by friction only on a prepared surface;
c) Strike anywhere matches are matches that can be ignited by friction on a solid surface;
d) Wax Vesta matches are matches that can be ignited by friction either on a prepared surface or on a solid surface.
Not restricted as per special provision a128
This entry only applies if it is demonstrated, on the basis of tests, that the substances, when in contact with water are not combustible nor show a tendency to auto-ignition and that the mixture of gases evolved is not flammable.
Not restricted as per special provision a129
Provided the ammonium nitrate remains in solution under all conditions of transport, aqueous solutions of ammonium nitrate, with not more than 0.2 per cent combustible material, in a concentration not exceeding 80 per cent are not subject to these Instructions.
Not restricted as per special provision a130
When this material meets the definitions and criteria of other classes or divisions as defined in Part 2, it must be classified in accordance with the predominant subsidiary risk. Such material must be declared under the proper shipping name and UN number appropriate for the material in that predominant Class or division, with the addition of the name applicable to this radioactive material according to column 1 of the Dangerous Goods List, and must be transported in accordance with the provisions applicable to that UN number. In addition, all other requirements specified in 2;7.9.1 1;6.1.5 must apply.
Not restricted as per special provision a131
Sterilization devices, when containing less than 30 mL per inner packaging with not more than 300 mL per outer packaging, may be transported on passenger and cargo aircraft in accordance with the provisions in 1;2.4, irrespective of 1;2.4.2.2 and the indication of “Forbidden” in columns 9 to 12 of the Dangerous Goods List (Table 3-1). In addition, after filling, each inner packaging must be determined to be leak-tight by placing the inner packaging in a hot water bath at a temperature, and for a period of time, sufficient to ensure that an internal pressure equal to the vapour pressure of ethylene oxide at 55°C is achieved. Any inner packaging showing evidence of leakage, distortion or other defect under this test may not be transported under the terms of this special provision. In addition to the packaging required by 1;2.4, inner packagings must be placed in a sealed plastics bag compatible with ethylene oxide and capable of containing the contents in the event of breakage or leakage of the inner packaging. Glass inner packagings must be placed within a protective shield capable of preventing the glass from puncturing the plastics bag in the event of damage to the packaging (e.g. crushing).
Not restricted as per special provision a132
Articles containing smoke-producing substance(s) corrosive according to the criteria for Class 8 must be labelled with a “Corrosive” subsidiary risk label.
Not restricted as per special provision a133
Substances must not be transported under this entry unless approved by the appropriate national authority on the basis of the results of appropriate tests according to Part I of the UN Manual of Tests and Criteria. Packaging must ensure that the percentage of diluent does not fall below that stated in the appropriate authority approval at any time during transport.
Not restricted as per special provision a134
Vehicles which contain an internal combustion engine must be consigned under the entries UN 3166 Vehicle, flammable gas powered or UN 3166 Vehicle, flammable liquid powered, as appropriate. These entries include hybrid electric vehicles powered by both an internal combustion engine and wet batteries, sodium batteries or lithium batteries, transported with the battery(ies) installed.
Not restricted as per special provision a135
Substances and mixtures meeting the criteria for Class 8 must be labelled with a “Corrosive” subsidiary risk label.
Not restricted as per special provision a136
a) These substances are liable to exothermic decomposition at elevated temperatures. Decomposition can be initiated by heat or by impurities (e.g. powdered metals (iron, manganese, cobalt, magnesium) and their compounds).
b) During the course of transport, these substances must be shaded from direct sunlight and all sources of heat and be placed in adequately ventilated areas.
Not restricted as per special provision a137
This entry must not be used for Division 6.1 substances that meet the inhalation toxicity criteria for Packing Group I described in 2;6.2.2.4.3.
Not restricted as per special provision a138
This entry applies only to calcium hypochlorite, dry, when transported in non-friable tablet form.
Not restricted as per special provision a139
“Fissile-excepted” applies only to those packages complying with 6;7.10.2.
Not restricted as per special provision a140
For the purposes of documentation, the proper shipping name must be supplemented with the technical name (see 1.2.7). Technical names need not be shown on the package. When the infectious substances to be transported are unknown, but suspected of meeting the criteria for inclusion in category A and assignment to UN 2814 or UN 2900, the words “suspected category A infectious substance” must be shown, in parentheses, following the proper shipping name on the transport document, but not on the outer packagings.
Not restricted as per special provision a143
These storage systems must always be considered as containing hydrogen.
Not restricted as per special provision a144
Protective breathing equipment (PBE) containing a small chemical oxygen generator for use by aircrew members may be transported on passenger aircraft in accordance with Packing Instruction 523 subject to the following conditions:
a) the PBE must be serviceable and contained in the manufacturer’s original unopened inner packaging (i.e. vacuum sealed bag and protective container);
b) the PBE may only be consigned by, or on behalf of, an operator in the event that a PBE(s) has been rendered unserviceable or has been used and there is a need to replace such items so as to restore the number of PBEs on an aircraft to that required by pertinent airworthiness requirements and operating regulations;
c) a maximum of two PBE may be contained in a package;
d) the statement “Aircrew protective breathing equipment (smoke hood) in accordance with Special Provision A144” must be:
(i) included on the dangerous goods transport document;
(ii) markedadjacenttothepropershippingnameonthepackage.
All other requirements applicable to chemical oxygen generators must apply except that the “cargo aircraft only” handling label must not be displayed.
Not restricted as per special provision a145
Waste aerosols are prohibited from air transport.
Not restricted as per special provision a146
This entry applies to fuel cell cartridges containing flammable liquids, including methanol or methanol/water solutions. including when contained in equipment or packed with equipment. Fuel cell cartridges installed in or integral to a fuel cell system are regarded as contained in equipment. Fuel cell cartridge means an container article that stores fuel for discharge into the fuel cell powered equipment through a valve(s) that controls the discharge of fuel into such equipment and is free of electric charge generating components the fuel cell. The cartridge Fuel cell cartridges, including when contained in equipment, must be designed
Not restricted as per special provision a147
Where substances have a flash point of 60°C or less, the package(s) must bear a “FLAMMABLE LIQUID” subsidiary risk label in addition to the hazard label(s) required by these Instructions.
Not restricted as per special provision a150
An additional subsidiary risk hazard label may be required by a Note found adjacent to the technical name entry in Table 2-7.
Not restricted as per special provision a151
When dry ice is used as a refrigerant for other than dangerous goods loaded in a unit load device or other type of pallet, the quantity limits per package shown in columns 10 and 12 of Table 3-1 for dry ice do not apply. In such case, the unit load device or other type of pallet must be identified to the operator and must allow the venting of the carbon dioxide gas to prevent a dangerous build-up of pressure.
Not restricted as per special provision a152
Insulated packagings containing refrigerated liquid nitrogen fully absorbed in a porous material and intended for transport, at low temperature, of non-dangerous products are not subject to these Instructions provided the design of the insulated packaging would not allow the build-up of pressure within the container and would not permit the release of any refrigerated liquid nitrogen irrespective of the orientation of the insulated packaging.
Not restricted as per special provision a153
Plastic aerosols of a capacity greater than 120 mL (IP.7C) are permitted only when the propellant is non-flammable and non-toxic and the contents are not dangerous goods in accordance with the provisions of the Technical Instructions.
Not restricted as per special provision a154
Lithium batteries, identified by the manufacturer as being defective for safety reasons, or that have been damaged, that have the potential of producing a dangerous evolution of heat, fire or short circuit are forbidden for transport (e.g. those being returned to the manufacturer for safety reasons).
Not restricted as per special provision a155
Magnesium nitrate hexahydrate is not subject to these Instructions.
Not restricted as per special provision a156
Ethanol and gasoline, motor spirit or petrol mixtures for use in spark-ignition engines (e.g. in automobiles, stationary engines and other engines) must be assigned to this entry regardless of variations in volatility.
Not restricted as per special provision a157
A fuel cell cartridge may contain an activator provided it is fitted with two independent means of preventing unintended mixing with the fuel during transport.
Not restricted as per special provision a158
Mixtures of solids which are not subject to these Instructions and environmentally hazardous liquids or solids must be classified as UN 3077 and may be transported under this entry, provided there is no free liquid visible at the time the substance is loaded or at the time the packaging is closed. Sealed packets and articles containing less than 10 mL of an environmentally hazardous liquid, absorbed into a solid material but with no free liquid in the packet or article, or containing less than 10 g of an environmentally hazardous solid, are not subject to these Instructions.
Not restricted as per special provision a159
A single package of non-combustible solid LSA-II or LSA-III material must not contain an activity greater than 3000 A2.
Not restricted as per special provision a160
Type B(U) and Type B(M) packages, must not contain activities greater than the following:
a) For low dispersible radioactive material: as authorized for the package design as specified in the certificate of approval;
b) For special form radioactive material: 3000 A1 or 100 000 A2, whichever is the lower; or
c) For all other radioactive material: 3000 A2.`
Not restricted as per special provision a161
Each fuel cell cartridge transported under this entry and designed to contain a liquefied flammable gas must:
a) be capable of withstanding, without leakage or bursting, a pressure of at least two times the equilibrium pressure of the contents at 55°C;
b) not contain more than 200 mL of liquefied flammable gas with a vapour pressure not exceeding 1 000 kPa at 55°C; and
c) pass the hot water bath test prescribed in 6;5.4.1.
Not restricted as per special provision a162
Fuel cell cartridges containing hydrogen in a metal hydride transported under this entry must have a water capacity less than or equal to 120 mL.
The pressure in the fuel cell cartridge must not exceed 5 MPa at 55°C. The design type must withstand, without leaking or bursting, a pressure of two (2) times the design pressure of the cartridge at 55°C or 200 kPa more than the design pressure of the cartridge at 55°C, whichever is greater. The pressure at which this test is conducted is referred to in the drop test and the hydrogen cycling test as the “minimum shell burst pressure”.
Fuel cell cartridges must be filled in accordance with procedures provided by the manufacturer. The manufacturer must provide the following information with each fuel cell cartridge:
Not restricted as per special provision a163
Chemical kits, first aid kits and polyester resin kits containing dangerous substances in inner packagings which do not exceed the quantity limits for excepted quantities applicable to individual substances as specified in [1;2.4.3] may be transported in accordance with 3;5. Division 5.2 substances, although not individually authorized as excepted quantities in the Dangerous Goods List, are authorized in such kits and are [assigned Code E2 (see 3;5.2)].
Not restricted as per special provision a199
Not restricted as per special provision a197
These substances when transported in single or combination packagings containing a net quantity per single or inner packaging of 5 L or less for liquids or having a net mass per single or inner packaging of 5 kg or less for solids, are not subject to any other provisions of these Instructions provided the packagings meet the general provisions.
Reference: here.
Not Restricted as per special provision codes (Air/UN)
