Office 16 Click-to-Run Extensibility Component
Setup Error
We can't install the 64-bit version of Office because we found the following 32-bit programs on your PC.
Please uninstall all 32-bit Office programs then retry installing 64-bit office. If you want to install 32-bit Office instead, please run the 32-bit setup
1. First, check any Office Applications (Including Visio) that are installed are not 32 or 64 per the version you require.
2. Re-install
Office 16 Click To Run Extensibility Component
Office 16 Click To Run Extensibility Component (28.36 KiB) Viewed 23721 times
