(CP_a046) Charging equipment communication lost Check power source and charging equipment
Charging stopped because communication between the vehicle and the external charging equipment was interrupted.
Confirm whether the external charging equipment is powered by looking for any status lights, displays, or other indicators on the equipment.
If the equipment is not powered, try to restore the external charging equipment’s power source.
• If attempting to charge at a public station and power is unable to be restored, contact the station operator.
• If attempting to charge at a private station (for example: charging at home) and power is unable to be restored, contact an electrician.
If the equipment is powered, try charging the vehicle using different external charging equipment.
• If the vehicle begins charging, the issue was likely with the equipment.
• If the vehicle still does not charge, the issue may be with the vehicle.
• Make sure the external charging equipment is powered.
• Try charging with multiple, different types of charging equipment.
You can also try charging your vehicle using a Tesla Supercharger or Destination Charging location, all of which can be located through the map on your vehicle's touchscreen display. See Range Assurance on page 72 for more details. Additional third-party charging stations may also be available in your area to help you to pinpoint the issue.
