High temperature detected by Wall Connector alerts indicate the building connection to the Wall Connector is getting too warm, so charging has stopped to protect the wiring and Wall Connector. This is not typically an issue with your vehicle or your Wall Connector, but rather an issue with the building wiring. This may be caused by a loose building wiring connection to the Wall Connector and can be fixed quickly by an electrician.
To regain normal charge operation, try the following steps.
If the Wall Connector is plugged into a wall outlet, make sure:
• The plug is fully inserted into the receptacle / outlet
• The plug / outlet area is not blocked or covered by anything
• There is no heat source nearby
If the issue persists or the Wall Connector is hard-wired,contact an electrician to inspect the building wiring connection to the Wall Connector. They should make sure that all wires are properly connected and torqued according to the installation guide for the Wall Connector.
(CC_a012) Unable to charge - Wall connection too hot Check outlet or Wall Connector wiring
