Your 15% Baby Registry Completion Discount is available now (Amazon)
The Arrival Date you entered in your Baby Registry is in less than 60 days ! As a Prime member, you're now eligible for the 15% Completion Discount on select items in your registry! Just visit your Completion Discount page to start saving.
Don't forget that:
You need to add items to your registry and purchase from your Completion Discount page to take full advantage of your discount.
You can use the discount on up to two orders with a combined value of $2,000.
Your Completion Discount expires 60 days after the Arrival Date you set in your registry.
Access Your Discount
Only eligible items that you add directly to cart from this page will get the discount.
The discount can be used on up to two orders of $2000.00 US Dollars combined value ($300.00 discount with Prime Membership). The discount is available 60 days prior to the Arrival Date you entered in your Baby Registry and expires 60 days after the Arrival Date.
Note, you can add up to 50 items to your Cart to apply your Completion Discount at Checkout. Any additional items added to Cart beyond 50 items will be moved to Saved for Later and your Completion Discount will not be applied to those items.
