Based on feedback from publishers with AMP sites, we’ve updated Auto ads for AMP to support anchor ads.
If you'd prefer not to show anchor ads on your AMP site, you can turn this option off using the controls on the “Auto ads for AMP” page.
What does this mean for me?
• From April 11th 2022, if you're using Auto ads for AMP, anchor ads will start to appear on your sites.
• You may see an increase in your AMP revenue.
• The change will apply to all sites that have Auto ads for AMP enabled in your AdSense account.
What should I do next?
• There's no action required from you for this change to take effect on your sites.
• See how AMP anchor ads are performing in this report in your account.
Sincerely,
The Google AdSense Team
Anchor ads will start serving on your AMP sites
