Dynamic Range Window violation
2022-03-28, 23:34:57 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:55 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:53 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Notice (6) TLV-11 - unrecognized OID;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:48 Error (4) Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:34:46 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:31:01 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:30:42 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:30:42 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:30:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:30:21 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:29:58 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:29:52 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-28, 23:29:49 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-25, 17:11:03 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-18, 16:18:37 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-11, 20:29:42 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
2022-03-06, 11:08:08 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=00:ca:e5:3c:a2:b1;CM-QOS=1.1;CM-VER=3.1;
