The VBA modules in this database appear to have been saved with errors.
Microsoft Access
The VBA modules in this database appear to have been saved with errors. Access can recover the modules, you should backup the database first. To cancel so you can make a backup copy of the database, click Cancel. Then make a backup copy of the database.
If you have a backup copy of the database, click OK. When the database opens, examine the modules to see that they are correct. If they are not, you should revert to a recent backup.
The Vba Modules In This Database Appear To Have Been Saved With Errors
The Vba Modules In This Database Appear To Have Been Saved With Errors (24.23 KiB) Viewed 7472 times
