DNS Response (135) (flags 8180) RCODE: NoErr (0) RD RA:<private> 4/0/0 <private>
[Q11418] DNS Query (42) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q11418] Sent UDP DNS Message 42 bytes from <private>:60400 to <private>:53 via (null) (0x0)
[Q13575] DNS Query (33) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q13575] DNS Response (49) (flags 8180) RCODE: NoErr (0) RD RA:<private> 1/0/0 <private>
[Q13575] Received UDP DNS Message 49 bytes from <private>:53 to <private>:56508 via en0 (0xf)
[Q13575] Sent UDP DNS Message 33 bytes from <private>:56508 to <private>:53 via (null) (0x0)
[Q14816] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q14932] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q15284] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q15967] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q16426] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q17219] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q1746] DNS Query (55) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q1746] DNS Response (153) (flags 8180) RCODE: NoErr (0) RD RA:<private> 6/0/0 <private>
[Q1746] Received UDP DNS Message 153 bytes from <private>:53 to <private>:56251 via en0 (0xf)
[Q1746] Sent UDP DNS Message 55 bytes from <private>:56251 to <private>:53 via (null) (0x0)
[Q1944] DNS Query (46) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q1944] DNS Response (110) (flags 8180) RCODE: NoErr (0) RD RA:<private> 3/0/0 <private>
[Q1944] Received UDP DNS Message 110 bytes from <private>:53 to <private>:62366 via en0 (0xf)
[Q1944] Sent UDP DNS Message 46 bytes from <private>:62366 to <private>:53 via (null) (0x0)
[Q20868] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q21278] DNS Query (54) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q21278] DNS Response (164) (flags 8180) RCODE: NoErr (0) RD RA:<private> 4/0/0 <private>
[Q21278] Received UDP DNS Message 164 bytes from <private>:53 to <private>:50279 via en0 (0xf)
[Q21278] Sent UDP DNS Message 54 bytes from <private>:50279 to <private>:53 via (null) (0x0)
[Q23119] DNS Query (42) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q23119] DNS Response (170) (flags 8180) RCODE: NoErr (0) RD RA:<private> 8/0/0 <private>
[Q23119] Received UDP DNS Message 170 bytes from <private>:53 to <private>:49976 via en0 (0xf)
[Q23119] Sent UDP DNS Message 42 bytes from <private>:49976 to <private>:53 via (null) (0x0)
[Q23384] DNS Query (33) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q23384] DNS Response (49) (flags 8180) RCODE: NoErr (0) RD RA:<private> 1/0/0 <private>
[Q23384] Received UDP DNS Message 49 bytes from <private>:53 to <private>:50258 via en0 (0xf)
[Q23384] Sent UDP DNS Message 33 bytes from <private>:50258 to <private>:53 via (null) (0x0)
[Q25869] DNS Query (45) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q25869] Sent UDP DNS Message 45 bytes from <private>:52836 to <private>:53 via (null) (0x0)
[Q28208] DNS Query (30) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q28208] DNS Response (76) (flags 8180) RCODE: NoErr (0) RD RA:<private> 0/1/0 <private>
[Q28208] InitDNSConfig: Setting StopTime on the uDNS question 0x7f84390136b8 <private> (Addr)
[Q28208] mDNSCoreReceiveResponse ignoring <private>
[Q28208] Received UDP DNS Message 76 bytes from <private>:53 to <private>:61116 via en0 (0xf)
[Q28208] Sent UDP DNS Message 30 bytes from <private>:61116 to <private>:53 via (null) (0x0)
[Q28581] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q29730] DNS Query (32) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q29730] DNS Response (64) (flags 8180) RCODE: NoErr (0) RD RA:<private> 2/0/0 <private>
[Q29730] Received UDP DNS Message 64 bytes from <private>:53 to <private>:61100 via en0 (0xf)
[Q29730] Sent UDP DNS Message 32 bytes from <private>:61100 to <private>:53 via (null) (0x0)
[Q303] DNS Query (32) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q303] DNS Response (64) (flags 8180) RCODE: NoErr (0) RD RA:<private> 2/0/0 <private>
[Q303] Received UDP DNS Message 64 bytes from <private>:53 to <private>:49445 via en0 (0xf)
[Q303] Sent UDP DNS Message 32 bytes from <private>:49445 to <private>:53 via (null) (0x0)
[Q30879] InitDNSConfig: Setting StopTime on the uDNS question 0x7f842c80a4b8 <private> (Addr)
[Q32160] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q32866] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q3331] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q33928] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q34354] DNS Query (58) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q34354] DNS Response (58) (flags 8183) RCODE: NXDomain (3) RD RA:<private> 0/0/0 <private>
[Q34354] Received UDP DNS Message 58 bytes from <private>:53 to <private>:52107 via en0 (0xf)
[Q34354] Sent UDP DNS Message 58 bytes from <private>:52107 to <private>:53 via (null) (0x0)
[Q35838] DNS Query (30) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q35838] DNS Response (76) (flags 8180) RCODE: NoErr (0) RD RA:<private> 0/1/0 <private>
[Q35838] InitDNSConfig: Setting StopTime on the uDNS question 0x7f843a00fab8 <private> (Addr)
[Q35838] mDNSCoreReceiveResponse ignoring <private>
[Q35838] Received UDP DNS Message 76 bytes from <private>:53 to <private>:50874 via en0 (0xf)
[Q35838] Sent UDP DNS Message 30 bytes from <private>:50874 to <private>:53 via (null) (0x0)
[Q35854] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q36280] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q3733] DNS Query (32) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q3733] DNS Response (64) (flags 8180) RCODE: NoErr (0) RD RA:<private> 2/0/0 <private>
[Q3733] Received UDP DNS Message 64 bytes from <private>:53 to <private>:57919 via en0 (0xf)
[Q3733] Sent UDP DNS Message 32 bytes from <private>:57919 to <private>:53 via (null) (0x0)
[Q37464] DNS Query (57) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q37464] DNS Response (57) (flags 8183) RCODE: NXDomain (3) RD RA:<private> 0/0/0 <private>
[Q37464] Received UDP DNS Message 57 bytes from <private>:53 to <private>:54488 via en0 (0xf)
[Q37464] Sent UDP DNS Message 57 bytes from <private>:54488 to <private>:53 via (null) (0x0)
[Q40932] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q4208] DNS Query (47) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q4208] DNS Response (63) (flags 8180) RCODE: NoErr (0) RD RA:<private> 1/0/0 <private>
[Q4208] Received UDP DNS Message 63 bytes from <private>:53 to <private>:56981 via en0 (0xf)
[Q4208] Sent UDP DNS Message 47 bytes from <private>:56981 to <private>:53 via (null) (0x0)
[Q42436] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q43382] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q44831] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q45225] DNS Query (55) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q45225] DNS Response (153) (flags 8180) RCODE: NoErr (0) RD RA:<private> 6/0/0 <private>
[Q45225] Received UDP DNS Message 153 bytes from <private>:53 to <private>:50429 via en0 (0xf)
[Q45225] Sent UDP DNS Message 55 bytes from <private>:50429 to <private>:53 via (null) (0x0)
[Q49866] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q5029] DNS Query (32) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q5029] DNS Response (145) (flags 8180) RCODE: NoErr (0) RD RA:<private> 6/0/0 <private>
[Q5029] InitDNSConfig: Setting StopTime on the uDNS question 0x7f842a8088b8 <private> (Addr)
[Q5029] Received UDP DNS Message 145 bytes from <private>:53 to <private>:63663 via en0 (0xf)
[Q5029] Sent UDP DNS Message 32 bytes from <private>:63663 to <private>:53 via (null) (0x0)
[Q5060] InitDNSConfig: Setting StopTime on the uDNS question 0x7f843b0120b8 <private> (Addr)
[Q5142] DNS Query (32) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q5142] DNS Response (135) (flags 8180) RCODE: NoErr (0) RD RA:<private> 4/0/0 <private>
[Q5142] Received UDP DNS Message 135 bytes from <private>:53 to <private>:61907 via en0 (0xf)
[Q5142] Sent UDP DNS Message 32 bytes from <private>:61907 to <private>:53 via (null) (0x0)
[Q5293] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q54183] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q56227] DNS Query (48) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q56227] DNS Response (136) (flags 8180) RCODE: NoErr (0) RD RA:<private> 3/0/0 <private>
[Q56227] Received UDP DNS Message 136 bytes from <private>:53 to <private>:58262 via en0 (0xf)
[Q56227] Sent UDP DNS Message 48 bytes from <private>:58262 to <private>:53 via (null) (0x0)
[Q5624] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q56812] InitDNSConfig: Setting StopTime on the uDNS question 0x7f842a80c2b8 <private> (AAAA)
[Q56812] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q57833] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q57930] DNS Query (42) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q57930] Sent UDP DNS Message 42 bytes from <private>:65511 to <private>:53 via (null) (0x0)
[Q63994] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q64099] DNS Query (42) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q64099] DNS Response (170) (flags 8180) RCODE: NoErr (0) RD RA:<private> 8/0/0 <private>
[Q64099] Received UDP DNS Message 170 bytes from <private>:53 to <private>:49214 via en0 (0xf)
[Q64099] Sent UDP DNS Message 42 bytes from <private>:49214 to <private>:53 via (null) (0x0)
[Q65420] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q6828] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q7073] DNS Query (45) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q7073] DNS Response (61) (flags 8180) RCODE: NoErr (0) RD RA:<private> 1/0/0 <private>
[Q7073] Received UDP DNS Message 61 bytes from <private>:53 to <private>:54315 via en0 (0xf)
[Q7073] Sent UDP DNS Message 45 bytes from <private>:54315 to <private>:53 via (null) (0x0)
[Q7892] DNS Query (45) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q7892] DNS Response (61) (flags 8180) RCODE: NoErr (0) RD RA:<private> 1/0/0 <private>
[Q7892] Received UDP DNS Message 61 bytes from <private>:53 to <private>:62647 via en0 (0xf)
[Q7892] Sent UDP DNS Message 45 bytes from <private>:62647 to <private>:53 via (null) (0x0)
[Q816] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
[Q9942] DNS Query (42) (flags 0100) RCODE: NoErr (0) RD:<private> 0/0/0 <private>
[Q9942] DNS Response (42) (flags 8183) RCODE: NXDomain (3) RD RA:<private> 0/0/0 <private>
[Q9942] Received UDP DNS Message 42 bytes from <private>:53 to <private>:58249 via en0 (0xf)
[Q9942] Sent UDP DNS Message 42 bytes from <private>:58249 to <private>:53 via (null) (0x0)
[Q9954] ShouldSuppressUnicastQuery: Query suppressed for <private> AAAA (AAAA records are unusable)
