tx_flush:1028: xid 676159 tx stats: #
tx_flush:1028: xid 676159 tx stats: # 1680 finish 1680 enter 1570 wait 72 6022us close 392us flush 2924us
tx_flush:1028: xid 676179 tx stats: # 1700 finish 1700 enter 1558 wait 72 6022us close 387us flush 2933us
tx_flush:1028: xid 676199 tx stats: # 1720 finish 1720 enter 1545 wait 72 6022us close 383us flush 2943us
tx_flush:1028: xid 676219 tx stats: # 1740 finish 1740 enter 1532 wait 72 6022us close 378us flush 2942us
tx_flush:1028: xid 676239 tx stats: # 1760 finish 1760 enter 1518 wait 72 6022us close 374us flush 2922us
tx_flush:1028: xid 676259 tx stats: # 1780 finish 1780 enter 1508 wait 72 6022us close 370us flush 2921us
tx_flush:1028: xid 676279 tx stats: # 1800 finish 1800 enter 1506 wait 73 5962us close 366us flush 2930us
tx_flush:1028: xid 676299 tx stats: # 1820 finish 1820 enter 1508 wait 74 6010us close 362us flush 2930us
tx_flush:1028: xid 676319 tx stats: # 1840 finish 1840 enter 1510 wait 74 6010us close 358us flush 2935us
tx_flush:1028: xid 676339 tx stats: # 1860 finish 1860 enter 1512 wait 75 5934us close 354us flush 2941us
tx_flush:1028: xid 676359 tx stats: # 1880 finish 1880 enter 1511 wait 75 5934us close 350us flush 2944us
tx_flush:1028: xid 676379 tx stats: # 1900 finish 1900 enter 1508 wait 75 5934us close 346us flush 2940us
tx_flush:1028: xid 676399 tx stats: # 1920 finish 1920 enter 1499 wait 76 5861us close 343us flush 2937us
tx_flush:1028: xid 676419 tx stats: # 1940 finish 1940 enter 1487 wait 76 5861us close 340us flush 2936us
tx_flush:1028: xid 676439 tx stats: # 1960 finish 1960 enter 1473 wait 76 5861us close 336us flush 2937us
tx_flush:1028: xid 676459 tx stats: # 1980 finish 1980 enter 1459 wait 76 5861us close 333us flush 2950us
tx_flush:1028: xid 676479 tx stats: # 2000 finish 2000 enter 1449 wait 76 5861us close 330us flush 2947us
tx_flush:1028: xid 676499 tx stats: # 2020 finish 2020 enter 1454 wait 76 5861us close 326us flush 2945us
Pato220
Re: tx_flush:1028: xid 676159 tx stats: #
Post by Pato220 »
Also the sane error after installing Catalina last update on a Mac Mini which worked perfectly. I have waited about 12 hours and it is still running, appearing new messages every 20 minutes. What happened? :(
Pato220
Post by Pato220 »
Finally! My problem is solved. If you have installed new hardware or driver (in my case a Roland MIDI cable) you have to remove it from KEXT from Library/Extensions folder using Terminal from Recovery Mode (Command + R at startup).
Here is the video which saved my Mac Mini.
