Vignette ads will start serving on wider screens (Google AdSense)
Vignette Ads Will Start Serving On Wider Screens Adsense
Vignette Ads Will Start Serving On Wider Screens Adsense (125.58 KiB) Viewed 1126 times
Vignette ads to show on wider screens from November 3rd 2020
Based on feedback from publishers using vignettes, we’ve extended vignette ads to include wider screen sizes. Our experiments show that vignette ads perform very well on wider screens.
If you'd prefer not to show vignettes on wider screens, you can turn this option off using the new "wide screen" control in your Auto ads settings.
What does this mean for me?
• From November 3rd 2020, if you're using vignette ads, this ad format will start to appear on your sites on wider screens such as desktop devices.
• You may see an increase in your vignette revenue.
• The change will apply to all sites that have "vignette" enabled in your AdSense account.
What should I do next?
• There's no action required from you for this change to take effect on your sites.
• See how vignettes will appear on your desktop sites by using the Auto ads preview.
• See how vignettes are performing in this report in your account.
